Wheel and tire vibration >
Old 05-25-2006, 07:23 PM
MK_Arbiter's Avatar
Default Wheel and tire vibration
The wheels and tires on my TA-05 are vibrating and i've already debonded them and reglued them but theres still a bit of it. Any way of fixing it?
MK_Arbiter is offline
Old 05-25-2006, 09:00 PM
tfrahm's Avatar
They are probably out of balance -- just as with full size car wheels, it can pay to balance sedan tires, expecially in Mod classes...
I use a Top Fliight "propeller" balancer... Go to a Golf shop and get some of the thin lead tape they sell for balancing golf clubs, and use it on the inside of the rim as "wheel weights" -- It's self sticking and soft, so if you put on too much, just slice a little off with an xacto knife... Easy...
This assumes that your axles are spinning on good bearings and not worn out ones or bushings....
tfrahm is offline
Old 05-26-2006, 04:39 AM
MK_Arbiter's Avatar
The tires are a bit out of shape too cause i ripped them when i unglued them. And they were stretched out when i re mounted them. does this mean i need to spen more money and buy new tires?
Old 05-26-2006, 04:44 AM
sosidge's Avatar
If you already ripped the tyres then I think you will be MUCH better off with a new set.
A lot of the wobble will be down to the play that most cars have out of the box. I tend to spend a little time shimming the cars out to get everything precise without drag.
Wheelbalancing is a pretty high-end thing to do - very few drivers do it, even at world level.
sosidge is online now
Old 05-26-2006, 09:38 AM
MK_Arbiter's Avatar
I'll test out the tires tonight at a race and see if they are still good.
Old 05-26-2006, 01:36 PM
the new batch of cs preglues are really badly molded in the uk and don't run true so look out for that.
Smoking motor.. is offline
