Camber setup
Camber setup
Is there an easy way to measure the camber angle without a setup board?
chamber gauge is available
hmm actually im not sure the name of the gauge
http://www.rcmart.com/catalog/produc...ducts_id=17124
Is there a way that doesn't require buying stuff? (trying to spend less)
Get a ruler - put it on the rims facing up. You want to use the side of the ruler to get a line.
Get a protractor and line it up... Easy..
Or make your own camber gauge. Not hard to figure out. Just rule a line, do a 90degree... then a 91deg, then a 92degree. Done.
Do it on stiff cardboard or plastic sheet..
Since I just got into RC for a few months, I am still confused and don't know how to use the guages.
