eXcelerate RC Prodigy Formula 1 >
Like Tree1136Likes
Old 08-29-2025 | 03:19 AM
  #661
Originally Posted by Dan
No, I'm not talking about the side to side. I have it shimmed so there is hardly any left/right movement of the bearing and the wheel still spins free. The bearing sits loose in the Excelerate wheels. Doesn't fit as securely as other F1 wheels, so it creates a lot of movement.
Tried at some point applying thin CA on the inside of the wheel but looking for different solutions or ideas.
Use a piece of plastic wrap, place over the bearing hole, and push the bearing through into the wheel. If that's too tight, just apply an tiny amount of 150-200k grease inside the wheel bearing hole and re-insert the bearing. This should ensure it does not spin inside the wheel and add enough tack to prevent it from falling out when you remove the wheel.
Dan and racenut123 like this.
kn7671 is offline
Old 08-30-2025 | 10:18 AM
  #662
Originally Posted by PROMODVETTE
I have some weight pans in stainless if anyone is interested. The cross on the battery weight is where the CG is. 2 different thicknesses, 1.25mm and .73mm. The triangle offset one is about 9.75mm from center and the half open one is about 14.8mm from center. $4 each, flat rate shipping of $7 no matter what you get.
I still have a few of these plates left if anyone needs some under electronics weight for your car. I'll go $12 shipped for both nose plates, add in battery plates for $2 on this deal!
PROMODVETTE is offline
Old 09-02-2025 | 07:01 AM
  #663
TheBeave's Avatar
I ran these for a bit before the steel chassis, if you don't want to sink the $$$ for the chassis plate then these plates are the way to go. They fit perfect and can get the weight more on the nose.
TheBeave is offline
Old 09-02-2025 | 11:02 AM
  #664
RE: Steel chassis plates
This is what I find frustrating about Excelerate - parts are released with zero input as to how they are supposed to be installed and / or adjusted.
I am building a car for a friend, and he has the steel chassis upgrade. The part comes in a bag with no instructions. From following this forum, I find it needs shims - whether it is 4 or 8 and how it impacts steering geometry, I am not sure. I go to Excelerate FB page to find more info, and in a comment it is mentioned that the CF front braces are not needed as well...........
I can't imagine it would take much effort to share how the parts are designed to be used.
racenut123 and MC Hamilton like this.
belewis01 is offline
Old 09-02-2025 | 12:38 PM
  #665
Welcome to Thunder Dome. Two men enter, the one that can figure shit out leaves...
LowDrag is offline
Old 09-02-2025 | 01:20 PM
  #666
Thanks - can always count on you for sage advice ..
I went with 8 shims - 4 to the battery tray and 4 under the front suspension mount - makes the most sense. Also - there are no holes for the rear of the front carbon braces - so no front carbon braces.
Good news - apparently the new kits come with the Pro Kingpins and Pro Kingpin adjusters - Bad news - no instructions ...... back to the Thunder Dome.
Kruss45 likes this.
Old 09-11-2025 | 10:55 AM
  #667
Nego's Avatar
No longer have time for this , if anyone is interested hit me up.
Exelerate prodogy F1
Nego is offline
Old 09-13-2025 | 04:40 PM
  #668
Would love to see a setup sheet from those who ran their prodigy F1 at the VTA nationals last week at apex
Kruss45 is offline
Old 09-15-2025 | 06:23 AM
  #669
Very cool design. Can’t wait to turn some laps with it
I still need to learn how to set things like ride heights and droop on it but I’m excited to learn a new platform
MC Hamilton likes this.
Kruss45 is offline
Old 10-02-2025 | 08:55 AM
  #670
https://synergyhobbies.com/index.php...roduct_id=2726
racing_jason likes this.
iandouglass is offline
Old 10-02-2025 | 09:34 AM
  #671
dr_hfuhuhurr's Avatar
What brand of spurs are people using? I've blown through 2 already and want something a bit more durable. Was thinking Kimbrough but not sure if those would fit the axle.
dr_hfuhuhurr is offline
Old 10-02-2025 | 09:38 AM
  #672
HD-F1's Avatar
From: In the car taking my kid to another race track.
We have murdered both Excelerate and Robinson gears, make sure the two screws that hold the axle down are tight. If they loosen up it gets really bad, I ended up going to a 3x12 on ours.
HD-F1 is offline
Old 10-02-2025 | 10:00 AM
  #673
Dan's Avatar
Dan
RW gears. The stock spurs from excelerate are way too flimsy and fragile for 1/10 f1. They'll work fine on a tc.
Dan is offline
Old 10-02-2025 | 10:19 AM
  #674
MC Hamilton's Avatar
Originally Posted by HD-F1
... make sure the two screws that hold the axle down are tight. If they loosen up it gets really bad, I ended up going to a 3x12 on ours.
I have been adding a small drop of blue Loctite to the two screws that hold the axle tube on. I've only had one loosen up on my 1/12th, but once is enough to make that small fix.
HD-F1 likes this.
MC Hamilton is offline
Old 10-02-2025 | 12:13 PM
  #675
What other hidden gems of information could you share? I just picked up my F1 and currently building my prodigy 12. I'll take all the help I can get!
Kruss45 likes this.
empaint3 is offline
