eXcelerate RC Prodigy Formula 1 >
Like Tree1136Likes
Old 01-04-2025 | 07:21 PM
  #211
Originally Posted by iandouglass
I'm in for some too if you'd like to sell them
Same here!
Martin Paradis
rhodopsine is offline
Old 01-04-2025 | 07:33 PM
  #212
Got to try the car for the first time last weekend. I'm very impressed. I was roughly 5 tenths quicker than with my Icon 2, with the box setup. I didn't have the time to play with the setup because I got a little agressive on the kerbs and the car smashed in the track barrier. Broke the small retaining pins on one of the side pivots ( I had the all aluminum first version in my kit...). I found that the car scrubs very little speed in the corners and can turn on a dime if needed, without losing rear traction. It's the easiest F1 car to push hard I've had so far. Very stable under braking and just very quick all around the track, even in the portions I was struggling to keep speed before. I'll be racing it tomorrow and I'm confident I can find even more pace out of it.
Martin Paradis
Casey Belarde and MC Hamilton like this.
Old 01-05-2025 | 10:19 AM
  #213
robk Are you running asphalt? Or just want the gear diff option? Clever work nonetheless!
iandouglass is offline
Old 01-05-2025 | 11:46 AM
  #214
robk's Avatar
No, a lot of times on the carpet tracks around here I prefer a gear diff. Just easier to drive if traction is not high, or if there are some track imperfections.
robk is offline
Old 01-05-2025 | 05:42 PM
  #215
I ran today on Asphalt- Had to run Exotech Red/Red because I needed the extra ground clearance (5.0). Our parking lot has quite a few crack that make the cars bounce. Having run a XRay for the last year - in the corners the car out handled my XRAY. I could even undercut my buddy in the corners something I could never do with my XRay (24). Just wish I could have used my Team Powers tires which I prefer. This coming week will be on carpet but I hear the weather is supposed to be even colder than today ( 41 to later 64 degrees by 10:30). I ran the kit wings. Forgot to mention I was running a XRay ball diff.
BullFrog is offline
Old 01-06-2025 | 07:39 AM
  #216
wallstreet's Avatar
Originally Posted by belewis01
Ran my car today at LEMO practice - same track as Ian reported on last weekend.
Build went well - be aware there are a few annoyances with the kit. Wrong part numbers in the manual, and no parts list for reference - I used the WGT parts list to figure out the manual discrepancies. I was also caught off guard by the steering servo - was unaware that it requires the MKS servo unless some fabrication or modification is done. In the end I ordered the MKS, but also I suspect a Savox 1251 or a team Powers DCS would be a close fit with some shimming required. Also there are no setup instructions included, and I am not aware of any setup sheets being published. Fortunately I have run F1 cars for several years and applied some standard settings for the 1st runs. It also helped that I have 2 Awesomatix A12s. Power is Team Powers V5 25.5, Team Powers mini Radon esc and Team Powers battery.
Enough with the grumpy bits - I was really excited to see this car, the design is unlike any other F1 and results from the Indoor Nats sealed the deal. I ordered on Black Friday and had the car in 1 week. The build was quick, and I found the car was very light - fortunately I have access to a CNC router and cut 2 chunks of brass sheet for about 80 grams of needed weight. The layout makes it easy to wire up, and it came out really clean. 1st run was mediocre - I only sauced 1/2 of the front tires, but there was a gunky buildup on the outside edge of the tires which lead to a massive push. 2nd run I sauced the entire front tire, but wiped the outside 1/2 immediately, the let the inside soak for about 10 minutes. From the 2nd run on the car was really good. I was playing chase with some F1 buddies and it is obvious the car excels at corner speed - if I was following, I would almost run over the car ahead when they slowed for corners. A couple of small setup tweaks and the car was faster and easier to drive - it feels very much like a foam tire 1/12 car
So, bottom line, I am very pleased, and several people at the track are very disappointed .
Would you be willing to make more front pieces? looking to buy 2. One for my buddy And one for myself
wallstreet is offline
Old 01-09-2025 | 08:38 AM
  #217
Got to race the car last weekend. I managed to find even more pace out of it. I managed to be a mere 2 tenth slower than the local fast guy (he's a much better driver than I am!) but more importantly I was able to drive the car fast with good consistency. Unfortunately, by the time the final was run, the grip got quite a bit higher and the car had a slight push that costed me the second place.
Few things I found out during the race day:
- When you set the camber, be careful when tightening the screw under, the kingpin can turn slightly and change the camber a bit if you tighten too hard.
- The champfer behind the spur gear on the wing mount is really recommended. Under certain circumstances, the spur can definitely rub on the carbon piece and you will strip your spur in no time.
- Axon DTS spur gears are a direct fit and, in my opinion, are more durable than the stock spur gear.
-Unless you can run a really big pinion, spurs smaller than 96 teeth cannot be used, the motor cannot be moved close enough for the pinion to mesh properly with the spur.
- Montech front wings will fit if you break the stock wing, but you will need to make the part that screws on the chassis thiner and the front body post will be off so you have to make another hole in the body.
-The body is really really thin... It cracks easily.
-The car is extremely light, I had to add over 120g to make the weight with an ULCG shorty. I'm thinking to try with a regular sized shorty to see how the car behaves.
-Car is quite sturdy as I had a couple hard taps with the wall and no breaks to report other than my front wing (and I thaink I would have broken pretty much any wing with that hit). Just make sure to check your camber if your front end taps the wall, camber will shift.
-The damper plastic pivots can move and twist under certain circumstances. Make sure they stay straight as if they twist, the damper rods may disconnect and the car's handling will get erratic. I found that putting a tiny drop of CA once the pivot is installed helps to keep it straight.
At my next race, I'll play with caster, side springs and damper oil to see how the car reacts to these changes. Last weekend, I focussed mainly on getting to drive the car consistently and getting confident with it.
Martin Paradis
Old 01-11-2025 | 05:45 PM
  #218
robk's Avatar
All Prodigy podium at the Motiv All Star Series race today
robk is offline
Old 01-12-2025 | 08:31 AM
  #219
The revolution has begun
I am replacing the flex pivots with the updated, steel pin units - and was just attempting to remove the bump stops from the older ones. That didn't go well.
My guess is that they are to be treated as "one time use" kind of parts. They immediately just sheared at the threaded section and then I immediately placed an order with Amain with rush shipping 🫠
I am wondering if anyone has determined a good way to remove those? I am wondering if I should have used a flat Xacto blade and tried to use it like a flat head - slightly pressing into the "top" of the bump stop button head, and then turning?
Or am I right in that they are just one time use?
Also, Josh had mentioned to me in a short convo that one reason we may be popping off the Damper Pivots, is due to the center of the chassis not being in perfect L to R alignment with the leaf spring and outer chassis.
He mentioned that if you look at the car from the bottom, you may see that the battery tray isn't perfectly centered - and that the damper pivot that pops off is usually on the more open side of that equation.
Hope that helps you guys!
MC Hamilton likes this.
Old 01-12-2025 | 09:38 AM
  #220
I have spare bump stops if you don't get yours in time - I'll be at LEMO Friday morning.
Bruce
belewis01 is online now
Old 01-12-2025 | 11:29 AM
  #221
Dan's Avatar
Dan
The pink bump stops are considered almost one time use and need to be replaced regularly, even when your car is not in use.
I sheared mines trying to twist it off (you can sometimes twist it off if you do not twist it all the way too firmly and it has not had much use). I ended up just popping them off with the end of a 1.5mm driver.
Stock up on a lot of them. They compress over time and your settings will change. It should be considered a regular maintenance item.
Hope to race with you guys at LEMO again when I am back home visiting my folks.
MC Hamilton and belewis01 like this.
Dan is offline
Old 01-12-2025 | 05:39 PM
  #222
Did anyone ever figure out min/max teeth count for gearing?
PROMODVETTE is offline
Old 01-13-2025 | 08:22 AM
  #223
robk's Avatar
Josh told me to put a dab of grease on the stem, and thread them in as they have thread. I did that and mine came out fairly easily.
Dan and wallstreet like this.
robk is offline
Old 01-13-2025 | 09:09 AM
  #224
markt311's Avatar
Does the 40 grams battery weight come with the kit?
markt311 is offline
Old 01-13-2025 | 09:57 AM
  #225
No. The car is very lightweight so you will need some. I personally use SMC tungsten battery weight.
Martin Paradis
