1:10 Onroad track on Concrete?
Hi
We have been given the opportunity to use an abandoned car park as a permanent track.
It is 30+ year old with concrete.
Size is 40x18 meters.
We will steam wash the track, but wonder what to use to get traction up.
Sugar/ Asphalt Renewer (sealer)/ Paint ??
My question is, is there anybody with experience to get a concrete track to work?
All feedbacks are appreciated..
We could never get concrete to stick in the old days, but we got lucky here in Mesa, AZ. P&F Hobbies opened a very large store in a local mall and some of our club guys went over to help him put in a carpet track. They needed to level the concrete inside the store, so they hired a contractor to sand the entire track area. Then they figured, better seal it off and they used a 1 part epoxy paint, satin black (not gloss). Since carpet is so expensive they figured, might as well try it out and the traction was fantastic. Heck we sprayed it once with sugar water and never sprayed it again. We just would blow off the dirt/foam and occasionally mop the entire area. We had so much traction that we had to glue TC tires because of traction rolls. Unfortunately the place only stayed in business for 2 years, but it was fun while it lasted.
My feelings were that the sanding was what gave us the traction. However, your concrete already looks pretty rough. You may try just spraying with sugar water or soda and try it out. Or you might try painting it with the 1 part epoxy paint in black satin. Good luck, pretty sure you can get it to work. There are other outdoor concrete tracks, I know of one in Florida under a shade in the Tampa area and it has good traction. Good luck.
Super Moderator
Hi
Super Moderator
rubber sealer is the best if they can afford it sealer with sand will not last that long ,we have ran many races at our current track with the rubber sealer with “zero prep” just blowing the track off and the laps are only about 1-2tenths from a prep day. It’s now about a year and half old and still has texture to it .
Thanx for the feedback.
We have some buckets of the Latex-Ite Airport Grade Sealer.
Anyone with experience with that?
I'm thinking of a small track on my side yard. Would asphalt be the way to go? Or is concrete ok?
Perfect. Thanks!
You can also use squeegees to put down either the rubber or latex sealers. We have used the latex sealers over asphalt with excellent results. I hope your feelings don't get hurt if the guy doesn't use what you recommended. That statement at the end sounds like you are upset.
