M 210mm chassis class help >
Like Tree6Likes
Old 04-29-2023, 06:53 AM
Default M 210mm chassis class help
Hi, I would like to start racing in the M chassis 210mm wheelbase class but I'm not sure what I should be looking for given the various options. I've seen the Tamiya M05 and M07 cars and also the HPI Cup Racer. Are there any other cars that I should consider? I looking for good handling and durability. Any comments are greatly appreciated.
tc3thatflys7 is offline
Old 04-29-2023, 07:23 AM
gigaplex's Avatar
What are the class rules at your track? FWD or RWD or 4WD? Any restrictions on brand etc? Mini classes are often Tamiya only. If you're looking for other options, the Xpress FM1S is great. 3Racing MG EVO is another option. If you're strictly after 210mm wheelbase, the M07 isn't suitable, it only does 225 or 239.
gigaplex is offline
Old 04-29-2023, 09:31 AM
I believe it's a 210mm Four wheel drive class.
Old 04-29-2023, 10:52 AM
sosidge's Avatar
That class was popular near me a few years ago and the Xpress 4wd mini was the dominant choice.
I would visit the track first and see what is being run. In my opinion that class has passed its peak, I'd make sure there was a good following for it before spending money.
gigaplex likes this.
sosidge is offline
Old 04-29-2023, 11:03 AM
I appreciate all of the comments. I am leaning towards the XM1S. Generally, is the 4wd easier to drive than the Fwd? I am planning on running it with a mini cooper body.
Old 04-29-2023, 11:13 AM
DirkW's Avatar
4WD and FWD are about equally easy to drive (especially compared to RWD), but typically 4WD can accelerate harder than FWD.
DirkW is offline
Old 04-29-2023, 04:07 PM
Just an FYI - the M07 mentioned in the opening post can't be built to 210mm WB out of the box.
BuggyFan21 is offline
Old 04-29-2023, 04:10 PM
The Tamiya M05 and M07 are popular choices for the M chassis class due to their good handling and durability, as well as a wide range of available hop-up parts. Another option to consider is the Yokomo YD-2 M, which is a rear-wheel drive car that has been gaining popularity in the M chassis class due to its excellent handling and drift capabilities. Other notable options include the Kyosho Mini-Z MR-03 and the Xpress Execute XM1.5, both of which offer good handling and durability as well. Ultimately, the best choice will depend on your personal preferences and budget.
alpenglowquasar is offline
Old 04-29-2023, 04:31 PM
DirkW's Avatar
While true, this has already been mentioned in the very first reply within this thread.
The OP is explicitly looking for the 210mm option, so the M-07 (as had already been stated within this thread) would not really fit his requirements.
DirkW is offline
Old 04-29-2023, 04:46 PM
Vertebreaker's Avatar
Mini-Z's are 1/28 scale. They are not in this same class of vehicles.
Vertebreaker is offline
Old 04-30-2023, 12:22 AM
sosidge's Avatar
Nice to see ChatGPT has joined the forum with their usual blend of good grammar and bad information.
varmint and gigaplex like this.
sosidge is offline
Old 04-30-2023, 08:48 AM
The HPI cup race isn't a viable option - it's been discontinued for a long time.
Xpress, Tamiya and Serpent are good kits in their own right. Xpress mini series for the cost, Tamiya M series for its flexibility and bonkers parts support, and Serpent X20 mini for it's flexibility and high end race chassis DNA.
I personally run an X20 mini and the thing is stupid fast with a 17.5 in it.
Sabin is offline
Old 04-30-2023, 09:01 AM
M03 is ok in this class...
bertrandsv87 is offline
Old 04-30-2023, 10:00 AM
Thank you all for the comments. After comparing the options I decided to go with the Xpress FM1S.
Old 04-30-2023, 03:00 PM
gigaplex's Avatar
Is there a reason you chose a front wheel drive kit for a four wheel drive class?
gigaplex is offline
