Schumacher eclipse 5
#136
Aha, didn't know that. As I have seen setups use motorspacers, I thought it was usually the other way around. I usually check weight distribution by first doing "tweak" with no springs and moving weight around. Haven't really paid that much attention to the rear pod, any good pointers on how to best check it? just put the chassis on blocks and seeing if the pod sags?
#137
#138
For Pod balancing I disconnect the sidelinks, the tubes, but put on a pair of rearwheels so it won't fall that hard and is a bit easier to balance. Dont forget a pinion. (Picture is whithout tires).
Then I use the same pins to balance a regular car, of the schumacher U3852. The front pin kan be shifted left to right, make sure it's centerd. Or else the balacing will be off.
Regards Robert
#139
I'm 99% sure I know what your problem is.
As long as you have made sure your pod is straight, your links are free, but not sloppy, and that the tweak is ok, there is one more thing that is very easy to overlook. It's kind of hard to check, but hold the chassis where the links are mounted with your thumb and middle finger, and do the same on the pod. Try to feel the slop in your center pivot. Most probably it is some slop. Use AW- grease or some other nice grease on the ball, and tighten as much as you can without it binding.
Your car will feel amazing
Could it be a characteristic of running a spool or the track itself?
#141
#142
Regards Robert
#143
#144
Are you using a carbon axle in spool?
Carbon axle twists noticeably when power is applied and the left tire has a slight initial lag compare to the right tire.
Steel axle doesn't have this problem due to better torsion resistance.
#145
Anybody have an idea if the Eclipse 4 and 5 share the same body post setup?
In case they are, I uploaded a bumper for the eclipse 4 to thingiverse.
https://www.thingiverse.com/thing:6490030
Have fun with it if it fits.
#146
Yes, I am running the stock carbon axle. Thank you for the information!
#147
Where do I look for non-carbon spools?
#148
