Xpress Arrow AT1S
#106
Due to the weight of the car and what it takes to balance it out, it does make sense to use a shorty pack. I built mine 50/50 F/R with a full size pack, but it was difficult to achieve this without making the car overweight. Shorty would be much easier if nothing else.
I like the way my car handles @ 50/50 but I've only raced 21.5, it could well be different in a faster class. The fast guys have found more weight forward, as much as 52/48 F/R is faster, at least in the faster classes.
I was going to give it a go, but the battery plate I bought for an AT1 doesn't fit the AT1S as the motor mount is different.
#107
I'm pleased to find the inside the the gear cases to be free of any wear particles/dust as others have reported. There is no noticeable wear after a few months of racing. I used a dry PTFE spray on the gears.
The prop shaft vibrations were always a concern to me so I decided to upgrade to the alloy prop shaft. It's a direct fit, and has removed all the vibrations. A worthwhile upgrade in my opinion.
#109
Centred the fan position with this Exotek mount. Air will be blowing across the whole can now, not just just half. Hopefully provides better cooling. Risky though I know.
#112
Does anyone know if the XQ2S and AT1S body mounts are in the same locations?
#114
One of the internal screws in the diff came loose and destroyed the side gears. The parts are cheap, but I decided to upgrade to the AT1 diff. They all slotted in, tuned free without any noticeable binding. However, the spool had no noticeable backlash/play which I didn't like. There is not a lot of adjustment available but it is possible to move one of the 0.1mm shims to the other side which made the difference.
#116
Going to pick up one of these to race in VTA on CRC carpet as my first race-level TC (I've raced off-road and Mini-Z for about 3 years now) and planning to get the beige gears, DCJ front driveshafts, and aluminum hexes to start- Anything else I should buy to go with it? I've got my electronics already and am looking foward to getting into on-road racing this year.
