Tamiya TB Evolution V
#646
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
nope nothing bent or broke (keep checking after each race i`m that bad )
but i changed the setup quite alot from kit & now it is really hard to drive consistence, one corner it be allright the next be bad & the same corner next time round will be different again
hold my hands here & just say changed it to much from kit for it to work,thinking i know it all what do tamiya know
still made A on thurs eve though but it was so far of pace it even made my motors look slow coz it handled so badly
#647
Racereport
setup:
Carpet
Tires rubber sorex 24 on disk Proline insert orion blue mid
shocks
front white tam - oil 50 asso
rear blue tam - oil 40 asso
Camber rear 3°
Camber front 2°
gearing 48dp 74 to 21
rest standard
I have lowered the turnbukle arm on rear bulkhead. I removed the shims and replaced them by lower shims. That was the trick
The car was handeling very well. Still have a viberating sound when I'm turning in. Is it possible that it comes from the shaft and there's nothing to do about it?
setup:
Carpet
shocks
Camber rear 3°
Camber front 2°
rest standard
#648
to agp,
The noise that is coming from the wheels are the universal shafts. You have to remake them. And Please Put Some GREESE in the axle and the Cup joint.
It should help,
It should help,
#649
Hello,
I used to have a TA05 and planning on going back racing again and thinking of getting the EVO 5, but I have some questions and I hope you can answer them for me.
How is the handling compared to TA05 (for TA05 owners)?
Is it a tank just like the TA05?
and are parts easily available right now(online U.S. shops)?
Thanks.
Thanks.
#650
Comparing to the TA05,
This is a pro car not a toy like the TA05 were you have to buy optional parts to get the car runing.
The parts that you really need, you can get. The parts of the msx415 are the same like arms, steering blocks, ... .
Optional parts are not so easy to get. Still waiting for some of them to come out.
Regards
Regards
#651
stu rand
#652
Regards
Regards
ALSO is there an optional fornt diff.that you can buy or does it come with one.
TNX
#653
Front ball diff. Not yet. You have to buy all pieces sepertly. But the car is to handle white the oneway.
#654
Originally Posted by cheehtae
Please don't get me wrong, I have been racing for quite a bit now and I have had 415, xrays, hpi some others. the only reason I'm comparing this to an 05 is because it's the best damn out of the box TOY that I have ever driven. But still thanks for your input.
TNX
TNX
#656
Originally Posted by TryHard
only an Evo5 diff will fit. TRF415 Diff (front or the new rear one) won't fit.
There is a list of parts you need a few pages back.
HiH
Ed
HiH
Ed
#657
Tryhard, mrJolly,
Is it possible when cornering the main shaft makes a vibrating sound, because of the speed and the craft? That's what it feels like. Any of you have it. The shimming is ok that I know for sure.
#658
Mine doesn`t .my car is well quite ,weather it crashe`s or not
really front UJ`s ,any grease on them ??
#659
please explain uj??
#660
Universal Joint?
