Tamiya TB Evolution V
#2386
haven't been racing in ages.
so here is my down time ball diff project car for 21 blinky.
donor car 2nd hand ex-japan and the V1 exo 5 chassis.
up to electronics and waiting for s towers and short shocks
#2388
Low On Parts
I was looking for Evo 5 Hop-Ups and Spare Parts on the Tamiya USA site.
-There isn't any Hop-Ups left.....(scary)
Old Chassis? But; where's the long-term parts support?
Get what you can.....Now.
#2389
shock towers will also fit from a TRF 419.
Really the biggest worries would be bulkheads and the chassis decks.
for the chassis decks they aren't available but fiberlyte in the UK support many older cars
So I'm sure if given an evo 5 chassis they would be able to produce decks if needed
#2390
TB03 and 04 diffs will fit the car. suspension components are easily replaceable with the older TRF 415/6 style that was fitted or can be converted to the newer TRF 418/9 style that I run on my car.
#2391
Thanks for the info AW106.
I don't need parts yet. But I was thinking about getting a new Lower Deck(Chassis). I'm too late. . .?
#2392
Like I said fiberlyte in the UK produce a lot of parts for older RC cars. Alternatively if you can make a technical drawing or know anyone that can you could get a new chassis deck made pretty much anywhere that can cut carbon sheet
Hi, random question, but you seem to have expertise on Tamiya cars. I'm looking to get a bsr m.rage but they have issues with plastic diff out runners. You can get a part for another car, from NitroRc. Mad-3119 diff joint. But these are no use as I'm in UK and shipping is a joke. On investigation, the tb03 evo diff joint cup 'looks' the same but I can't find specs to be sure. Is it possible these parts are the same? Cheers, jj
I would be happy to measure any parts to see if they're compatible. Shoot me a PM
#2393
If I can't get the genuine-factory parts(some spares) for the chassis; I will put it on the shelf.
(looks like it's coming to that soon)
#2394
In case anyone is interested in a one or two RARE race ready Exotek EVO5 conversions each in excellent condition, take a look! http://www.rctech.net/forum/r-c-item...e-chassis.html
#2395
RS4 Sport 3 vs Evo 5
I put the HPI RS4 Sport 3 with the Stock 15T Brushed Motor against the Evolution 5 with the Reedy M3 10.5T Motor(0° Timing) in a Fastest-Lap Challenge.
(each chassis best lap)
-HPI RS4 Sport 3 - 40.33
- -Gearing - 64P - 98Spur | 34Pinion
-Evo 5 - 39.92
- -Gearing - 96Spur | 37Pinion
(I know I can get a better fast-lap. The sun and heat got to me early - 8a.m.)
I will set-up the track and try again.
-Evo 5 - 39.92
#2396
I put the RS4 Sport 3 against the Evo 5 in a Fastest Lap Challenge again. (cooler morning)
-HPI RS4 Sport 3: - 39.80
-Evo 5: - 36.59
-Evo 5: - 36.59
#2397
Better O-Rings. . . . . . .?
I use the Tamiya Competition O-Rings - item # 42137.
I'm thinking about using these Muchmore O-Rings - item # MK-FOX40.
Which O-Rings are better?
#2398
In case if anyone's looking for an upgrade from standard TB Evolution 5 to MS spec chassis, I have a spare-built never ran for sale.
Looking for $150 shipped.
PM me if interested.
#2399
Uneven Sway-Bars...?
These (Stabilizer Rods)Sway-Bars (item # 49395) are uneven. I have a problem with the Front Sway-Bar not lifting the Right Suspension Arm evenly (it's off by 1mm).
I'm think'n about installing a better link system.
Anyone have (or had) that problem?
#2400
Sway bars
You don't need to buy new stabilizers. The ones you have should have set screws and adjustable links. You need to begin to adjust the set screws so that they appear even. You might need to invest in a micrometer. The vertical adjustable links are there to adjust the uneveness you are experiencing. Start adjusting before spending.
