Tamiya TB Evolution V
#2101
Haha! Like your style Clint. I've been thinking about doing a floating servo mount for my "version 2". I hadn't thought about a floating steering rack though. Can I steal your idea? I've been away from RC for about 6 years and am just learning about all the current trends. So it looks like version 2 will be narrower, MUCH lighter, and less connection to the top deck. I'll tell you what. You let me steal your floating rack idea and I'll make a second chassis for you at cost + shipping. I have no idea what the shipping would cost but it should be waaaay cheaper than $220 ;-)
#2104
Get the Evo6 gear diff parts. That's the upgraded and lighter diff version. One more tip. If you switch to Evo4 larger gears. The drive train is instantly much more free.
#2105
I was at Tamiya last week. The asphalt is breaking up with LOTS of debris right now
Like Juan says clean out the teeth every run. The covers will not fit over the TB04 diff but it will still run nicely. I would run spool up front with the cover and then put a lexan shield over the rear input gear. The direction of the rear gear wants to suck debris in from the top fyi.
Are you running 13.5 or 17.5?
#2107
Just waiting on top plates. The machinist is backlogged so looking like June at this point. Will be worth the wait I think
#2108
If you are running 17.5 you almost don't need a diff gear- the weight difference from ball diff to TB04 gear diff is huge and the ball diff really doesn't diff out (if built right) with 17.5
need one for my evo5 and my evo5 MS
#2109
Any news on the above mentioned exotek stuff??
#2113
here July is winter time. now it feels like Christmas!
#2114
