Tamiya ESC LED Flashing?????????
I'm trying to program this speed control and all that happens is the led keeps flashing
model # Teu-101bk and the radio is a airtronics model #92623
what the h*ll is going on... i have tryed everything??
anybody have anything my 5year old wants his truck to run
and i dont want to put the mech speed control back in
it really kills batterys
direct link to the manual..
http://www.tamiyausa.com/pdf/manuals/45029ml.pdf
could be in setup mode?
I have the manual
i have followed it and the light keeps flashing is there a way to reset
how do you get it out of setup ?
yes i did and still flashing
Tamiya America, Inc.
Attn: Customer Service
2 Orion
Aliso Viejo, CA 92656-4200
Phone: (800) TAMIYA-A
Fax: (949) 362-6852
Customer Service Hours
Monday through Friday, 8:00 a.m. to 5:00 p.m. PST
*shrug*
do you leave the 7.2 battery discounted and the motor?
still need some help with this
any other ideas
I experienced the same problem with this esc that was brand new and bundled with the M03 mini cooper kit. It basically never gets out of setup mode, I tried using different receivers, hooked up a motor and all it did was make beeping sounds.
Fortunately the shop that I bought it from were happy to replace it. The shop owner said a bad batch of them got released from Tamiya.
This is when there is no signal from the reciever. The best way is to very the radio works, might be another car, or maybe use a rx battery, and servo.
The BIGGEST problem I have found is (as above) you MUST use the TWO cable and plug them into the reciever. The second plug is what powers the speeder from the other plug.
good luck
Kevin
good luck
Kevin
still looking for more tips
