Dusting off a AE TC3 gearing with brushless?
#16
Clueless
Getting the diff to lock on acceleration, even with a 21.5t, is the real issue...The slipping on black carpet is terrible. I heard steel balls will have more bite than ceramics or carbide, but they will not last as long...I am still experimenting to find a good solution, but the diff bolt keeps snapping with a 4.5t on black carpet...The key is to find enough friction to lock the diff gear ring and the outdrives when power is applied, without much diff spring tension....I will be moving up to 3.5t on crc black carpet to experiment some more....
#18
......i do believe there's a meme with an amusing sound byte originating from G.T.A.-" Aww ***, here we go again ! "( and this isn't even the Tc-3/4 thread ). Anyways , i'd hope the OP gets some clarity on the gearing.-greg
#19
#21
Maybe it is my level of english which is a problem there but I don't understand why, if you know that there is an issue with a 21.5T motor, will you go for a 4.5T, then for 3.5T... What's the point here? Have you every considered that the issue is probably coming from the excessive grip provided by the Black Carpet? Have you tried it in other conditions?
#22
#23
Have used the 17.5T & 21.5T Justock from the Vegas IIC spec and amateur classes. Ball diff holds well for these motors.
Getting the FDR into the 3.4 - 3.8 range for these motors requires 50-56T pinion with a 74-76T spur, and that size pinion requires dremeling out the webbing in the chassis under the pinion. Structurally no harm done.
Setup I use is really close to the stock kit recommendations with less droop in the rear, ~3-3.5 on black carpet.
Fun running the TC3 mid-pack against all those Carbon/Ti beauties.
#24
To answer all of you guys here, the ball diff is at a disadvantage against a gear diff(no slip) because of unavoidable slip, no matter the brushless motor used: that inherent slip increases the tc3/tc4 laptimes 0.2sec or more per lap... I want to use a 3.5t motor due to less initial torque eventhough more power is available later in the powerband: less torque around turns when diff slip is high and more power down the straight to make up some time on the gear diff cars...I don't know why associated did not make a gear diff for the tc3/4, but with my 17.5t motors at 3.9fdr to 4.0fdr, I struggled alot to keep up, not realizing that the ball diff had alot to do with it....Anyway, good luck with your tc3, and see you at the track soon....
#25
AE didn't make a gear diff for the TC4 because they'd already moved on to the TC6 before sealed gear diffs became popular.
#26
We're a little off the original posts topic, but I still race well with my TC3 on black carpet.
is your gear 64 pitch or 48?
