Roche Rapide F1 EVO3
#212
Chassis
New to f1 and got a killer deal on an evo2 and 3. Lots of spare parts including gear diffs as well as the ball diffs and spool. Will be running on asphalt outdoors, but both are aluminum chassis. Is there any need or a must to fit them with carbon chassis? Also will be running carpet to which one would be better to setup for carpet
#213
CF lower pod plate
Is there a carbon fiber lower rear pod plate or only aluminum. Buying a cf main chassis to convert to outdoor and curious if cf pod plate needed/recommended as well!
#214
delete.
#218
Someone knows if the Xray rear pivot blocks could be used at the Roche?
#219
Lower arm pivots
when will part #’s 340178 or 340187 be available again ? Several of the cars use these same part #’s , thnx .
#221
Are there any rumours about a new Roche F1? Maybe the Evo4 then.
Or when dou you expect a news message for release?
What changes would you expect for the new car?
If someone knows more but don´t want to post in public, please PM me.
Thank you.
Thank you.
#222
Evo3 carpet
Just picked up an evo3 i will be running on crc black carpet. Is there a good setup sheet I can find?
#223
R/C Tech Elite Member
#224
Chassis skins
Where can I find a chassis skin for my evo3
#225
Just get a roll of vinyl at Hobby Lobby apply it and cut the excess with a xacto knife.
