Roche Rapide F1 EVO3 >
Like Tree119Likes
Old 08-04-2023, 06:11 AM
  #151
idbdoug's Avatar
Trader Rating: 41 (100%+)
Originally Posted by LowDrag
I'm also looking for a lower arm pivot 340178. These are nowhere to be found either. Is Roche going to do another run of parts for 2024 soon? Why is there so many components out of stock?
I believe Roche international website has them in stock
idbdoug
idbdoug is offline
Old 08-04-2023, 02:12 PM
  #152
Fresh EVO3 build along with my traditional pre-race inventorying of tires
I ran an EVO2 for about 2 years, upgraded it with EVO floating servo mount and it was running good, but I got the bug for a new car. Searched online for about a month and all I could find was a US Spec kit - then Low Drag posted looking for aluminum chassis, we talked a bit and I ordered an Aluminum kit and a replacement carbon chassis. Aluminum went to Low Drag, and I built this one up as carbon. Fully expecting an EVO4 to drop next week now.
Impressions of the 2 vs the 3
Servo mount is so much better on the 3, especially if you change the wheelbase at all - never have to readjust the servo linkage.
I like the side spring adjustment better on the 2, but I guess this will force me to remove the side dampeners when I set the tweak.
Rear ride height adjusters - I was annoyed about having to buy the optional bearing holders for the EVO2 - but now that I have them, the height adjust is more flexible than the 3.
EVO3 is 14 grams lighter than my EVO2.5 - must be the rear pod? I had to fab up an under battery brass plate to make weight (1020 grams)
I'm still happy I got an EVO3 - especially now when I see the new XRay - went through the presentation and just said - EVO has that, EVO has that too.
hanulec likes this.
belewis01 is offline
Old 08-05-2023, 09:37 AM
  #153
Did you make that battery holder strap? Looks like a router table behind your car.
LowDrag is offline
Old 08-05-2023, 10:00 AM
  #154
hairymuffin's Avatar
Trader Rating: 105 (100%+)
Yes I’m really curious about the battery strap also
hairymuffin is offline
Old 08-05-2023, 10:27 AM
  #155
Yep, I made the battery holder, it's an evolution from the one I ran on my EVO2 and one my son designed for ULCG batteries. Needs some work as I had to shim it up for the EVO3. Trying to figure out how to make it accommodate different brands and sizes of batteries without shims, but I don't think that will work.
The CNC is a StepCraft router - works great for carbon fiber, plastic, brass. It's running a couple times a week typically, making parts for friends and family.
Old 08-05-2023, 10:54 AM
  #156
Here’s what I came up with.. 3d printed a strap that won’t rotate, a fan/wing mount, used the old Evo wing mount directly to the pod. A clean side tube/spring mount without the janky aluminum wing mount would be nice.
LowDrag is offline
Old 08-11-2023, 11:29 PM
  #157
idbdoug's Avatar
do you sell these mods especially fan mount?
idbdoug
idbdoug is offline
Old 08-13-2023, 03:08 PM
  #158
idbdoug
I'll just send you the .stl files if you want to PM me your email. You can print them yourself if you have access to a 3d printer.
LowDrag is offline
Old 08-13-2023, 03:29 PM
  #159
idbdoug's Avatar
pm sent, thanks
idbdoug
idbdoug is offline
Old 08-28-2023, 05:25 AM
  #160
nova2015's Avatar
I have an Evo 2, with a broken aluminium centre pivot mount ( number 210202 ). Will the mount from the Evo 3 fit the older chassis ?
nova2015 is offline
Old 08-28-2023, 05:49 AM
  #161
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
it would need a bunch of parts-
hanulec is offline
Old 08-29-2023, 06:21 PM
  #162
fat500's Avatar
Trader Rating: 51 (100%+)
so the lower arm piviot is out of stock on the whole planet.....340178 or 340187...Any Ideas what to do? roche intl web page is down too...
lbsnoopy likes this.
fat500 is offline
Old 08-30-2023, 03:18 AM
  #163
Rouleau's Avatar
Trader Rating: 18 (100%+)
Get a hold of Krazedbuilds located in Connecticut on Facebook. I had him make me carbon lower arms and I used Roche part number 340092 and 310077 with the o ring and haven’t had any issues since
hanulec and Robbob like this.
Rouleau is offline
Old 08-30-2023, 05:16 AM
  #164
Wow, great idea, thanks for sharing. I already hit him up for some.
Robbob likes this.
LowDrag is offline
Old 08-30-2023, 12:37 PM
  #165
fat500's Avatar
Rouleau....thanks, just got a set.
fat500 is offline
