Yokomo BD11
#227
This is a good base setup used at Yatabe arena which runs on high traction ozite carpet.
He’s using 1.0 mm spacers under the arms.
20 mm crank arms
15K diff oil
6 hole pistons
Front tower outer most hole
Rear tower middle hole
droop from the center of the pin
front 9.5 mm
rear 8.5 mm
front sidewalls are glued about 60 mm
twister body
#228
Hello,
Just picked up a cheap BD11 and wondered what the recommended Diff Fluid would be for a small indoor medium grip carpet track running 17.5. I've seen 3000 and 7500 mentioned but I don't have context of the track.
#230
look great.
I just got myself a bd11 after a long break from R/C since 2015. that time I was running yokomo bd7 black edition.
Now I'm still not very sure about the setting of the newer car.
i saw you are using the bd12 c-hub ? it is direct fit in ?
how is the feeling running shorty pack compare with normal long pack lipo ?
