GT12-RT
#991
Location: A step closer to where I need to be a step further from where I was
RW
#993
Does anyone know if the schumacher gear diff will fit and work in the awesomatix A12? Also what size spur gear can you use with the gear diff?
Has anyone had a bad experience building the awesomatix gear diff?
#994
R/C Tech Elite Member
I am used to XRAY instructions so take it as you will.
I thought the instructions to build the awesomatix gear diff sucked and I was never able to get it as free as I could the XRAY gear diff. That being said it's still way better than a ball diff and I can now gear correctly. If they were available again in mass I would buy a few more. Unless of course XRAY releases a gear diff that supports a spur gear with 10-15 less teeth than the current one, but I'm not holding my breath.
#995
Going out of state gave me a bit of a reboot to staying with on road. We started our summer series Sunday. 20 for GT12
B main.
https://youtu.be/5JbwQobltNY
A main.
https://youtu.be/0qNxgLlD-fA
B main.
A main.
#996
Awesomatix USA: Awesomatix A12 Gearing Considerations for Stock 17.5 and GT12 21.5 Racing
#997
I never had a problem with the ASMX gear diff. There is one piece that needs to go in a specific way, but it's mentioned in the instructions. The nut that locks it all down is quite thin so you'll need a decent 12mm wrench. ASMX sells a 3D printed wrench to help with this. The allowable gear sizes are mentioned in the literature.
#999
What do you guys suggest I go with for the awesomatix gear diff on medium bite black crc carpet?
#1000
No issues with smoothness with my Awesomatix gear diff too. In fact, I think it might be smoother than my Xray diff, but it does take a little more effort for maintenance and tear-down.
