What power supplies are you using?
#16
I think many companies don't realize how many potential customers they are losing when they have no pictures and/or decent descriptions of the product. Take the new Integy 36 amp power supply for example. Enjoy the picture, because that's all you get. Sorry for venting, but it really "gets my goat" when companies are so lazy like this.
#17
Well I'm running just a an ICE charger, but I'll be running two chargers soon. A Duratrax ICE and an Orion Advantage w/ LiPo. At this time I'm running a Integy 10amp/13.5 max psu, so I'm wanting to keep it light. Also I'm also trying to spend less than $150.
RH
RH
#18
I run a powertech (from jaycar) MP-3088 (25A, 30A peak), has volt/amp meter on front, multiple outputs, adjustable voltage, etc. but because it's a regulated unit, it's pretty big, and heavy.
I want to get a smaller unit, but all small psu's are generally switched mode, and "crap".
I'm considering the much more worlds 24A PSU.. but I've heard bad things at my local track (unit's failing) can anyone comment?
Here's a pic i took just then, here at work on my desk, doing some batt maintenance ready for tonight's racing. thats a CTX and CTX-D... both less than a week old.
#19
Originally Posted by rc-zombies
most bang for the buck get the Pyramid PSV200
20amp.. more than enough to power your electronics.
http://cgi.ebay.com/Pyramid-20-Amp-R...QQcmdZViewItem
HAHA, thats what i run. Running 2 ice chargers and a few cooling fans, and not one problem.
#20
Radio Shack power supply
#21
guys,
thoughts on chassis-style switched mode PSU's? cheap... could go two of these
http://www.rcmart.com/catalog/produc...oducts_id=4263
James
James
#23
Looks like an Integy power supply,except the one they have is only 14amps. I'd rather get one that has a fan, I know the one I have now does not have one, but since I'm only running one charger it does not even get hot. A little warm but not hot.
RH
RH
#24
Has anybody shopped at Dinball? They have the TMM PSU for $139 http://www.rcmart.com/catalog/produc...ducts_id=17799
RH
RH
#25
Has anyine use the LRP 14 amp power supply? Is this any good i was going to get one. Will it power 2 chargers DURATRAX ICE & LRP COMP 2?
#26
14 amps is to low in my opinion for two chargers, especially since that is the max amps it puts out.
RH
RH
#27
Well guys lets just say for the cost of the CE, MM, Radio Shack or rivergate you can get two of these shipped to your door.
I have had one for a year and half the other a year. Neither have ever even popped a fuse. Only once did I over draw from it and that was my mistake when I hooked up a super inefficent motor to the motor master.
http://www.buyreliant.com/psupplies/psv200.htm
They are 20amp supplies.
I use one for both MM chargers and the MM fan setup
and the other for MM motor master, lathe and Team Wave discharger.
-Shookie <><
Plus they are small. not as small as the CE or the MM but close.
-Shookie <><
#28
RH
RH
#29
How is shipping to the US? Also has anybody used this psu? http://www.rcmart.com/catalog/produc...ducts_id=16126
RH
RH
#30
RH
RH
Uhhhh.. that's one hell of a disclosure.
1. DO NOT operate the power supply when your hands are wet.
2.DO NOT leave the power supply under direct sunshine.
3.DO NOT place flammable, chemical and container under pressure around the power supply during operation
4.DO NOT leave the power supply unattended during operation.
5.DO NOT attempt to disassemble the power supply.
6.KEEP AWAY from children.
7.MUST use in an well-ventilated area and temperature below 30℃
8. Battery Option Limited will not liable for any revenue loss, indirect consequential, incidental, punitive damage or other lost and damages.
You get what you pay for, don't be cheap.
