Destiny RX-10SR 3.0
#91
008-racer pm sent
#95
So I have my car ready for USGT racing. My question is, what spare parts will I be needing to keep on hand? Weak points, or parts that often fail. The car looks great, can't wait to get in on the carpet.
#96
The driveshaft blades on the front spool like to split and crack in a 5min run or two so are basically consumables (suppose depending on how much power/brakes you have as in UK it's 17.5/13.5/mod)
Seen a few bent front driveshafts too on impacts, bent one myself on piping but was surprised how little impact it took (must have been the perfect angle in my case)
Keep spares of the little o ring by the spur as they like to snap or be cut off during spur change lol.
Keep an eye on bolts and ball ends coming loose (like on all cars) Ive found mine really likes to loosen the top links on the bulkhead ends.
Ball ends are also soft aluminium seen a few of those bend.
#97
Front and rear camber plates love to bend on these definitely need spares, I made carbon in the end which have lasted well.
Ball ends are also soft aluminum seen a few of those bend.
#98
So, I have been doing some testing and have my first race in USGT with the car. I have found quite a bit of speed with the car now. The biggest changes have been 2.5mm spacer added under upper/inner arm pivots, 1mm less shim on pivot balls on the steering center plate. I am running a Yokomo rear springs. 2.6 and 2.65 have both been really good, with 2.6 giving slightly more steering. I managed to podium the first race i ran the car. I am about a tenth off the top 2 for fast laps, but I am also not running a Bwoah body, and I run a 3 year old motor and battery. They both run AX with all the best and latest electronics and batteries. I drove the 2nd place driver's car and could not turn any faster lap with it than my Destiny, so I feel like the tenth of a second is most likely just skill level. I also run the race program, so I did not get any test time and just 1 heat race that day. Let's hear how others have been doing with the car.
#99
So, I have been doing some testing and have my first race in USGT with the car. I have found quite a bit of speed with the car now. The biggest changes have been 2.5mm spacer added under upper/inner arm pivots, 1mm less shim on pivot balls on the steering center plate. I am running a Yokomo rear springs. 2.6 and 2.65 have both been really good, with 2.6 giving slightly more steering. I managed to podium the first race i ran the car. I am about a tenth off the top 2 for fast laps, but I am also not running a Bwoah body, and a 3 year old motor and battery. They both run AX with all the best and latest electronics and batteries. I drove the 2nd place drivers car, and could not turn any faster lap with it than my Destiny, so I feel like the tenth of a second is most likely just skill level. I also run the race program, so I did not get any test time and just 1 heat race that day. Lets hear how others have been doing witht the car.
#100
Hi,
Had my first run with the 3.0 last weekend in 13.5 and I came away quite happy with it, Only made a few small changes from the stock setup and only using a few of the option parts available I have a good base setup.
#101
More of an FYI for ppl. This car is very sensitive to diff oil wt.
My 3.0 was brilliant when i first got it (Very low grip asphalt). towards the end of the year made big changes for a high grip track and after returning it back to stock settings it had changed in to a very unstable car.
Off power and neutral power it would over rotate/spin out. i tried every change i could think off but nothing worked - body, chassis, deck, suspension, tyres radio, esc settings etc
In the end it was the rear gear diff. I was running 3k oil in it, my friend lent me one with 5k and it felt softer than my 3k. The car settled right down, so I rebuilt mine with 3k again and its back to how it was when i first started running it.
I assume in a crash it put some pressure into the outdrives, it wasn't enough to feel turning it by hand but the binding was enough to unsettle the car.
I'd like to point out too - another friend with an ARC has 5k in his diff that feels like putty compared to ours with 5k but the ARC is dialled in.
#102
#103
#104
Has anyone heard more on the new bushing front drive shafts that are supposed to be available this month? I am anxiously awaiting to order them. I feel like this is the only thing this platform is lacking to be as fast as AX and Xray cars. I am so close, but the driveshaft drag in long sweeping on power corners is all where i feel it will help.
