3racing Cero Ultra V1 & V2
#392
3Racing Cero Sport just arrived at TQ RC Racing.
FYI, Thank you.
https://www.tqrcracing.com/shop/prod...?s_maker_id=56
FYI, Thank you.
#393
Does anyone know if the Sport lower arms have the v1 or v2 dimensions?
#395
I haven't started on the shocks yet but I think they are plastic. already stripped out one of the rear upper arms trying to get the turnbuckle grub screw started and ended up over penetrating the ball cup breaking it in half. only place with them in stock is Hong Kong.
Damn looks like top fuel has the parts in stock. bummer.
#396
Super Moderator
#397
#398
I dont have a 4mm reverse thread tap sadly.
#399
R/C Tech Elite Member
Not sayin', just sayin'...I've built three Ceros (two Ace and one sport) and have yet to strip out one of these upper arms. I am absolutely nothing special so I don't understand how people are having issues. I wonder if there are a few different core pin sets they are using in their mold tooling creating some variability. Either way, it seems possible to get these together without issue.
#400
When I built my Ultra I drilled out the ball cup hole a little bit before running the screw in. The holes are undersized for a 4mm by quite a bit. I did the same for the arm and tapped the arm. I have been running the car since November without a issue. Bw sure to use the included holder when threading into the ball cup. It makes things a lot easier.
#401
#402
it was the last one I had an issue with. parts already came in. the super expensive fedex option from HK is worth it. order to door step like 3 days. car is all done sans shocks. I HATE building shocks. always have. lol
does anyone have a setup sheet for asphalt parking lot racing? TIA
#404
#405
Use a 4 mm tap then 😉, as for the counter tap, maybe borrow one from NASA 🤦🏻
I don’t have one of these yet, I’ve been kicking the tyres before I pull the trigger.
My current asphalt car should be sold tomorrow. Seems my only available choice would be an Ultra Ace with Carbon chassis,
