Schumacher Eclipse 4 >
Like Tree138Likes
Old 01-27-2021 | 10:34 AM
  #16
Originally Posted by liljohn1064
The spec tires were announced on Facebook yesterday. The kit comes with the truing arbor. Schumacher is one of the few companies that comes to market with all parts in place,
Yes, but it is only them making them. Until BSR, CRC, Ulti, etc make them, they will never be used at an event, unless Schumacher/Contact RC is the race sponsor. And then no one would show up until the other manufacturers change as well. I like the idea, just think it is not really an issue that needed to be fixed. Going from 2 bolt to 3 bolt was due to not having to reset/rebuild your diff every time you changed tires, not for being lazy, lol.
chensleyrc1 is offline
Old 01-27-2021 | 12:38 PM
  #17
liljohn1064's Avatar
I can see where it would impact hand out tires for an event. I'd just have the other diff/spool handy. They advertise the lilac stripe as American spec. I wonder if the foam is from BSR or at least the same supplier?
liljohn1064 is offline
Old 01-27-2021 | 01:44 PM
  #18
I imagine it came from BSR. And like someone else said above, at least the 3 bolt hubs are cheap to have on hand for events
liljohn1064 likes this.
Old 01-27-2021 | 03:35 PM
  #19
Airwave's Avatar
So it is the end of the diff in 1/12 pancars... It is quite good because most of Schumacher ones were as bad as they could be. By the way, I'm sure the diff will remain needed on low grip carpet... and asphalt!
Airwave is offline
Old 01-27-2021 | 03:59 PM
  #20
I've never had a problem with a Schumacher pan car diff. Which I believe they invented.
Flygio, 3DFLYER, gigaplex and 1 others like this.
Old 01-27-2021 | 07:34 PM
  #21
3DFLYER's Avatar
Schumacher diffs best diffs I've used, from my experience with Roche, yokomo and AE. All my Eclipses never had a issue.
Flygio likes this.
3DFLYER is offline
Old 01-28-2021 | 03:50 AM
  #22
simple's Avatar
Last edited by simple; 01-28-2021 at 03:57 AM. Reason: not relevant to conversation
simple is offline
Old 01-28-2021 | 06:40 AM
  #23
My complaint isn't about cost. And it's not really a complaint. More like reality. The car doesn't seem to be that much different than the 3, except for the wheel attachment. I like the car, just don't see the need to replace the 3 when I can't run my club spec tires(orange stripe) on it. Sure, I can purchase the adaptors, but now I'm basically back to a 3. It's not about cost-it's about utilizing the "upgrades". Just my .02
Stitch44 is offline
Old 01-28-2021 | 07:22 AM
  #24
Dan's Avatar
Dan
Yep, not much changes from 3 if someone has already purchased an aluminum chassis and gone spool anyways.
Dan is offline
Old 01-28-2021 | 02:18 PM
  #25
gigaplex's Avatar
Originally Posted by Dan
At least the 3 hole hub is only $10. Hopefully the industry moves to single M4 nut down the road. No point in 3 screws.
Glad to see an aluminum chassis and solid axle come standard in the kit.
I like being able to adjust the diff without taking the wheel off, adjusting the diff on my F1 car is a pain in the butt.
gigaplex is offline
Old 01-28-2021 | 11:59 PM
  #26
Robert K's Avatar
Personally I think there is much of a differnce,
In this highly competative class where even the tiniest things make a difference, I think the E4 has a lot of new features.
- The big Bore dampers are different, yes you could buy them separately
- The space (or mounting hole) for a mass damper up front is a big difference compared to the E3.
- The front kingpins have a different coating and although the E3 had a option to get TI coated Kingpins I think this is a good new feature which improves the front end. And yes you could buy them separately
- The Front end Flex characteristics are different and although this is a small adjustment it can do a lot.
- The rearpod being “stronger” and les prone to tweak is a benefit for the more “common” racers like myself.
Al in all a lot of small things you make it a big improvement if you ask me. You could buy them separately but the you will probably end up paying the price of half a kit. I personally would invest and buy the new kit so I have all the new features.
Regards Robert
Robert K is offline
Old 01-29-2021 | 02:33 AM
  #27
gigaplex's Avatar
Meanwhile I'm looking at this kit and wondering how much it'll cost to switch it back to a carbon chassis and ball diff for our low grip asphalt tracks.
Stitch44 likes this.
gigaplex is offline
Old 01-29-2021 | 12:56 PM
  #28
The new type of axle and tyres save 18% weight in rotating unsprung mass. I think this is a clear significant improvement.
Andy Murray talked about the setup for different conditions in the E4 presentation video, he considers diff remains only for really low grip. For this the diff is kept available. For hand out tyres the spool with 3 screw mount is kept available. Watch yourself:
I wonder, why a carbon chassis would be preferable in low grip. Aluminium is more heavy and lowers the center of gravity, thats why it is used in my opinion - this should not hurt on low grip too. Advantage of carbon is that you can use heavier RC components and still keep the weight limit.
Best regards, Erhard
Erhard is offline
Old 01-29-2021 | 03:07 PM
  #29
gigaplex's Avatar
Flex characteristics affects handling, plus you don't really need that low of a CG on low traction tracks as it won't ever traction roll. Plus asphalt absolutely shreds alloy chassis to bits.
Airwave and Erhard like this.
gigaplex is offline
Old 01-29-2021 | 04:33 PM
  #30
Andy Murray's Avatar
Thanks to everyone offering the nice comments, it's really nice to see people appreciating our efforts! (I'm one of the Schumacher design engineers)
I'll try and offer some thoughts on some of the points:
Hex Lightweight Spool and Hex 1 nut wheel design:
We really wanted to try and maximise the performance potential. Its also important to innovate and keep the class moving forwards. With any luck, other manufacturers will follow on with this and bring an easier age to 1/12 racing in future.
It gives 3 main advantage, its lighter, so improved unsprung mass for cornering improvements and rotating mass, for speed. The wheel flex is improved and provides more equal flex and consistency going into each part of each corner. Its also much quicker and simpler to change tyres.
**The Jt3-38USR and JT2-38USF is a USA spec foam control tyre, although I appreciate some racing with specific brand control tyres will force an axle change to the traditional wheel fitment.
If you don't like the change its fine, there's many options available:
-Run what you have for the axle already.
-Get the eclipse 4 diff set U8171 or specifically bagged for the eclipse 4 traditional wheels spool set U8178 (coming soon).
-Stick with your eclipse 3/ other car / rear axle design
Gigaplex+Erhard: C/F chassis is likely to work better for low traction outdoor tracks, the flexibility and higher centre of gravity tend to create or feel like they create more grip.
We had to release the car with the best suited most common spec. That means medium and high traction conditions for 1/12 racing.
-Gigaplex, this car doesn't have a differential to set, again solid rear axles are becoming the most common/ standard for 1/12 racing, more often than not, so we wanted to include it. *F1 only: For your pain with F1 class diff's I feel your pain. Soon the Icon f1 diff will get a cheap update part which setting tension means only loosening 1 wheel. *
-Dan/Robert, thanks, we agree it carries lots of DNA from the Eclipse 3.. Having said that I think from a picture or distance it probably looks more similar than actually is. I think Robert covers it quite well, although theres probably some further differences maybe not so obvious such as:
-the new damper tubes x3 are big bore, more durable but also improved handling consistency and particularly handling in bumpy conditions. They are shorter, and no heavier. So the weight is positioned better.
-For these shorter dampers rear carbon parts are changed to adjust the damper positions, including the chassis to perfect the centre damper length.
-The front kingpin is improved in 3 ways over the eclipse 3 part. It can be fitted to an eclipse 3. The damping lasts longer and is improved as the oil output holes are re pitched and are always now within the hub, at all bump and droop positions. This also prevents excess oil squirting out when damping refreshed. There is a small diameter lip added to the base to prevent the hub carrier sticking when on full droop. The surface finish is also vastly improved for a much smoother suspension action.
-Front flex is adjusted to offer slightly more, and therefore less initial 'twitchiness' with better mid corner steering. This is via both the slightly amended top decks, and front lower beam profile. This lower beam also benefits from nicer fitting sockets secure by o ring rather than glue.
-The mass damper is now compatible in the front end unlike the Eclipse 3 chassis/ front end.
-Although the pod was robust and quite tweak free in the old model, the Eclipse 4 is now even more reliable and less likely to tweak with a new pod base design.
-Various other changes to bring the kit spec in line with most commonly used team driver parts such as the 1.5 camber strap, alloy chassis as standard and chassis location to fit an optional ~1gram 25mm fan mount facing the speed control in the centre of the car.
-New bumper plate to cater for slide in spacers such as MT020034 (montech) for easier front ride height adjustment.
Some of these things are not so obvious when looking at the car at a glance in the images. Yes you could pick and choose which parts you think are worthwhile to you, and update your eclipse 3, just there are maybe more parts than it appears at a glance.
If you got this far, thanks for reading my essay..
Andy Murray is offline
