Serpent X20-M Mini >
Serpent X20-M Mini
Like Tree16Likes
Serpent X20-M Mini
Old 12-23-2020 | 10:05 AM
1/8 IC Fan's Avatar
Default Serpent X20-M Mini
Serpent new mini, can be Rwd, Fwd or 4wd. Unless posted already.
  • Serpent Adjustable 50mm shock with 12mm oversize shock body
  • Serpent Linear bigger bore springs
  • Dampers include machined pistons for best possible consistency
  • Traditional style ball raced LCG Anti-roll bar
  • Pivot ball suspension with small balls for simplicity and free movement
  • 4x style arm mount with adjustable castor
  • Easy diff and spool removal
  • Lightweight front spool with composite outdrives, bladeless
  • Extremely low center of gravity
  • Re-Active rear steering RRS system is standard
  • 1 piece shaft and motor mount allow easy maintenance and changing of spur gears
  • Same heave damper front and rear which is mounted below the diff/spool just above the chassis for lowest possible center of gravity
  • Durable and smooth gear differential
  • Carbon fibre chassis in 2.25mm as standard
  • Front and rear cvd axles
1/8 IC Fan is offline
Old 12-23-2020 | 01:19 PM
This looks awesome, might have to get one, would be great for smaller tracks like the local Hobbytown here.
Mitamiya likes this.
anthonyscardina is offline
Old 12-23-2020 | 01:35 PM
Billy Kelly's Avatar
My Xpress M chassis works great there. Now getting them to add the class....
Billy Kelly is offline
Old 12-23-2020 | 01:41 PM
I personally won't count on anywhere adding the class, I've just wanted a small form factor TC for a while since the sportwerks recoil and xray M18 pro both got discontinued.
Old 12-23-2020 | 01:50 PM
the Tamiya people won’t let there be a second M class
Old 12-23-2020 | 07:05 PM
1/8 IC Fan's Avatar
I think Mike R, is gonna be stoked. I see some Exotek in this cars future. I for one have found a great car to put under his Stuttgart body! This in RWD is gonna be a blast!
Old 12-23-2020 | 07:11 PM
Looks so charming. Am I the only one drooling over this?
miketom is offline
Old 12-23-2020 | 07:32 PM
TurnNBurn's Avatar
It’s nice, but holy cow, they went all out on the race technology, I’m guessing that someone somewhere must be racing these competitively, because it’s certainly priced as such.
Anyone notice that they also released a 40th Anniversary RTR version of the S240 ‘21?
TurnNBurn is offline
Old 12-23-2020 | 07:36 PM
Apprx. how much for this?
Dealer Xing is offline
Old 12-23-2020 | 08:36 PM
tony gray's Avatar
tony gray is offline
Old 12-23-2020 | 09:41 PM
Well, I'm out
Old 12-24-2020 | 07:49 AM
One of these days we just need to say "This weekend is Open Mini. Bring your cool cars." That said, the M07 and M08 are full on touring cars.... I have a MG Evo that I want to throw down sometime.
Raman and hobbyten like this.
Nerobro is offline
Old 12-24-2020 | 08:14 AM
Long time before that could happen
Old 12-24-2020 | 12:56 PM
tony gray's Avatar
As I have posted in other forums, for the price of the Serpent you can buy a FWD and a 4WD from say...Xpress, and still have money left over.
It's a cool concept, but at the projected price I can't see too many takers.
OSherman likes this.
Old 12-24-2020 | 09:58 PM
Isn't the point of m class that it's supposed to be a more affordable entry to racing than tc? That's some crazy pricing.
gus6464 is offline
