Is 60A enough for Blinky?
#17
So if it's your first TC for club level racing then 60A will be just fine. Especially the hobbywing justock which I think is one of the most popular at my club and probably the best value for money ESC for racing. I've also had the ESC paired to high spec motors such as an SMC low rider and Reedy S plus in 17.5 with no noticeable issues
#18
That's not too different to what I said though.
Starting with 5-6A and tuning from there because you know that it has already been track tested (either with the same motor, or with a similar performing motor) is not that different to just starting with a known good endbell timing value. Personally, I'll use the endbell that the manufacturer set as default as a starting point, but it doesn't really matter where you start, it matters where you end.
The problem is, most advocates of the 6A method just set the motor to 6A and run it like that. The Nick Adams reviews in particular will set every single motor to 6A and compare them at that setting, which heavily favours motors that work better at those timing settings.
#19
So even those who acknowledge the shortfalls of the 6A method are defaulting to it to an extent?
Come on guys, are we all just lemmings?
2017 EP ON ROAD Nationals in Australia, I helped a few of the guys in 21.5, and the Team Powers Actinium V2 was the dominant motor in the A main (5 of 10) and they worked best at 38-40 deg endbell around 2.1A on the analyser
One guy did use 6A I think, but pretty sure his motor fried as well.
But hey, if it's on youtube it can't be wrong
#20
Why are we going on about 6 amps for motors on a thread for esc . The guy asked about which esc is good for blinky let’s not fill this thread with extra stuff
also look at nick adams videos on esc just incase u go for a more expensive one show you which one to maybe avoid
and again I recommend hobbywing, nosram/lrp and tekin All had good power and brakes (on track)
#21
I see peaks of 90 ish amps on a 21.5 but that is in microseconds. you can drive around that.
#22
Yes its enough, and it does not affect your top speed. Fast guys tend to find the line that allows them to be on the throttle as early as possible and drive on edge. You might want to look at your batteries though. Old packs will suffer from huge voltage drop during load, which makes the faster guy seem cheating.
#23
I've seen old long stack 17.5 motors pull 100A in blinky on track. These are spikes where the current draw is momentary. My short stack 21.5 is indistinguishable on track from that old long stack 17.5 My sample rate for data was 10hZ and the sensor was only rated for 100A so it is possible that a higher sample rate and a sensor with more headroom would show larger spikes. This was all with old stand alone telemetry stuff. My new esc's have data logging, but I haven't really messed with it. I've recently turned to the dark side and built my first dirt oval car. Maybe instead of the hand me down esc the sprint car needs the esc with telemetry so I can answer some questions.
As other have stated how you drive can minimize heat build up, but ultimately those who have an esc with a higher amp rating can comfortably drive harder and not have to worry about overheating something.
#24
So 100 amp spike is fine the 60 amp hobbywing juststock is 60amps conti and 380amps peak so u have 280amps left
so unless it’s pulling more then 60amps around the complete track it’s fine
the just stock is a beasty little cheap esc only blown one from putting The leads the wrong way.
mine today was keeping up with the xr10pro g2 today no problems and no extra heat
17Likes
