Komodo Dragon
#61
thnx..with the same gearing this motor is way faster than my c2, almost too fast down the straight, but it was a little too hot for me at the end of the run, i did change to both purple springs and used the f brush, killer combo,but you only get like 2 runs with that brush, im going to try the 767 brush next.
#62
If you want to bump up the torque, drill a #56 hole in the center of the brush. It'll burn the brush in one run, but it is ballistic.
With a fan mine pulls 9A at 1V with Golds and it pulls 12A at 1V with the hole in the brushes.
#63
ok thnx, im going to try that hole trick, how far do you drill into the brush?
#64
Well, since they're pretty much fried after one run, just a couple mm should be more than adequate eh Tim?
Tony
Tony
#65
How much is #56 in mm?
#67
#56 is not 0.056inch, #56 is about 1.19mm.
#68
Tony
Tony
Yup. not too far. About 1-1.5mm. I have tried various depths and it does change things if you go deeper.
Tim
#70
Originally Posted by John Tag
I also trim the edges 5 thousands to help the heat issue.. Yea Tim hollow does too work well..
Tim
#71
#72
For what its worth-I ran my new EA KD19t last night and it was as fast or faster than my EA C2, but at 4 teeth less than the C2 (1.21")!!!
I did run it two teeth less (1.12")than a C2 TWO RUNS and it was starting to make the comm reddish on the 2nd run. I ran it a third time at one less tooth (1.09") and it pulled the whole run, but it was done after the third run.
I rebuilt it, ran it two more times at 4-teeth less (1.06" to 1.08")than a C2 and might have been a tad undergeared, but it was still fast and the comm looks like I just broke it in.
My C2 I ran at 1.21" and it was one run and done and fell off a little harder at end of run. The KD seems to pull the whole pack till the battery finally dumps!!
Ray
Ray
#73
Over heating dragon
Race it on carpet and must say it is the fastest 19-turn on the market for three minutes. Geared at 32/116 tires 55.5mm 767 brushes stock springs and also running duel motor fans, this motos is fast but also it runs super hot, how do I keep my dragon from burning
#74
Ray
Ray
#75
the komodo is awsome
hey i just put the komomdo in my elec. rustler. and it flys. i raced a guy with the camelion and i beat him no prob. the truck gose bout 35-40mph. i like it and im very impresed by it.
