Tamiya TT-02S or TT-02RR?
#16
Yep, the TT02S is a better base. Although if you are just going to bash it around and want to raise it for rally the TT02RR is good as you can run it in the higher configuration. This is not possible for the TT02S.
i have to admit, despite having top end cars, I still really enjoy running and racing the TT02’s
#18
The inner shim between the outdrive pin and the housing is not there (like in every other sealed diff we know) and the o-ring has the wrong size. Messing around with green slime will help two or three runs. Then the oil will fly around in your car
#20
You are overthinking this. If you want a fun car to bash with, then just get the RR. If you want something that will be competitive, look elsewhere. The TT-02S has a bunch of expensive, one-off parts made to retrofit the OLD long arm suspension (probably to get rid of old stock). I've been at this crossroad when I bought my 7-year old his 1st RC to race with. I chose the regular TT-02 over the S.... the RR was not available then or I would have bought that.
- Jose
- Jose
#21
- Jose
- Jose
Have you seen wtcc'S TT02KR yet? If not, then you should. Been following that build and is IMPRESSIVE!
#22
Yeah, I saw that one.
I dunno. While the TT-02RR seems interesting, it sounds like it's still cheap in a few significant and hard-to-fix ways. Maybe I'll just get another TB-04R and build that instead; I know from experience that car requires no upgrades or custom mods to work correctly.
#23
There's no reason to resist the TB-04R; it performs well and is a completely drama-free vehicle. It "just works". But I already have one, which makes it somewhat less interesting to build another than to build a TT-02. But I also don't want to get stuck with a vehicle that I might wish I hadn't spent the time to build and money to upgrade.
Maybe I'll wait another month and see if I still care.
#26
Because Tamiya offers a bunch of kits that are somewhere between cheap RTRs and all-out track racing cars, which means I can get a nice car that doesn't require special care. (aside from concerns about chipping carbon-fiber chassis, I really hate how much extra cleaning is necessary for flat chassis vs. tub chassis. flat chassis accumulate dirt, sand, and pebbles so much faster.) Also, I have an entire Banker's Box full of Tamiya spare parts, so buying another Tamiya means I wouldn't need to hurry up and buy spare parts before they inevitably get discontinued. It lowers the cost of operation and maintenance.
#27
