FDR
FDR
FDR question
Mine is 96/52 x 1:9 = 3.5 FDR
If I change the spur to 92 with with 49 pinion the FDR is about the same but will it effect the car differently?
All things being equal, there will be zero difference between the two regarding speed and acceleration. Doing the math, the second option is a micron lower in ratio which will yield a bit more torque. but hardly noticeable I think.
Now the physical difference is the motor will shift further back a bit with a smaller spur(assuming this is a rear motor car), therefore changing ballast. I typically like more forward wight biased toward the front if I can.
The 92 spur and 49 pinion will yield better laptimes on a short track, but the difference will be minimal...I am guessing it will be used with a 25.5t motor which might benefit more from a torque setup than a rpm one....
