xray t4f
#136
#137
#139
Got to run with the aluminum chassis this past Tuesday. (I also switched over to graphite arms)
I am sure the biggest difference for me was having to move the battery placement. I’ll be playing with weight and balance a lot over the next coming weeks.
I struggled a little with turn in, but wow I picked up corner speed. The car would drift if I tried hard enough.. I also tried the new Hudy premount wheels. Lighter weight than the Gravity mesh, but less flex than the Gravity 6 spokes.
#141
It's been hard to keep the chassis flat. It does have great corner speed and turn in was good. Need to try it without the spool, the car got tipping when traction came up.
#142
I did feel like I got more corner speed, and I can “feel”
adjustments more. I lost a bit of turn in, but I think I got that back.
I too am running the spool, but gluing the front tires like a TC seemed to help with the tippy part.
I keep meaning to try a 2.5mil diff...
#143
Those running a spool. what have you used for a spool on the car? Maybe I am looking in the wrong place but haven't seen one specifoc for the T4F
#144
#145
#146
Its the one from the T4.
https://www.amainhobbies.com/xray-38...a305188/p22680
#147
T4F on carpet
Did a couple of laps today at our local track. Tyres is Ride ETS without sauce. 17.5 motor with FDR 5.0.
Everything is pretty much box stock except for The springs.
https://youtu.be/CnEP7Hfiou0
#148
What's the car weight once you have installed this aluminium/brass chassis?
#149
