Gizmo Racing USA Genesis TC Kit
#332
So I just got my car in the mail today, Thank you Macrco's J for the chassis sir. So after close review I am looking to see how caster and Droop and measured? Can someone make a video and post it on here or is there a post on the facebook page on how to do this. I know I can buy caster doodles to measure caster.
2nd do you all feel that the AMX diff and Spool are better then the gizmo parts? Or does this offer more Adjustments with the car?
No advantages to the amx parts vs the Gizmo parts, just a running change.
#334
Love the bits of Trinity purple, now that's a sexy looking car build!
#335
Been getting a few questions about how the car is built. Until the official pictures can be put up, here are a few more of my car. As this was a pre production car, It should be noted that a few of the parts on my car are still the prototype parts (such as the sway bar links). However, the kit parts will be similar, just a bit more user friendly.
#336
Are those diamonds and trapezoids mounted under the stiffener cutting tool inserts?
#337
Good eye! Yes I have some tungsten weights that i use from various cutting tools. I got them from a local machining shop. The plates mounted under the pcs brace are the pinewood derby tungsten weights.
#339
#342
Super Moderator
Well ran the mid motor for the first time today and all I can say is Cristian hit a home run!! Ran the same set up same car in 17.5 and USGT ran 4-5tenths faster per lap in both classes and the corner speed was amazing ! Next time out I’m only racing one class so I can fine tune the set up
#343
Surface
#345
I just did a couple of short videos. The first is some changes i made since i ran the car the first time. Predominately for high bite black carpet. The last video is the mounting of a DBX.
