XRAY T4'19 SPEC
#631
What's the smallest spur gear that folks have fitted to the Xray T4'19? I'm running a 66T spur/44T pinion combo, but I want to get the FDR lower and I've run out of space for a larger pinion.
Don't want to spend $$$ on a spur that I can't get the motor far enough across to mesh with the pinion.
#632
Running on an outdoor asphalt track with medium traction. Looking for some advice on chassis weights. Is there a weight that is standard or recommended or just the typical weights used to balance out the weight of the chassis?
#633
Suspended
#634
Suspended
hope this helps
#635
#641
Suspended
not usually. It seems to make the car react quicker to steering input, but takes away a lot of steering mid-corner.
base setup is .5 down.
#643
Drive belts
In some parts of the world you can buy a person for what xray wants for the drive belts. What other brand belts are compatible with the 19.
#644
Plenty of other brands are compatible, Vigor, Radtec, Zerotribe, Yeah Racing just to name a few. Belt sizes are 3mmX189mm rear and 3mmX513mm front
#645
Running on an outdoor asphalt track medium grip and the car has a bit of off power push in the corners. Any suggestions? Was thinking less rear toe or lighter rear diff oil
