T.O.P. Racing "Scythe" 1/10 EP Touring Car
#61
set ups
hi,
does anyone have any set-ups for the scythe for 27T stock??
Thanks Luke
Thanks Luke
#62
Finished building mine
Most of the guys here suggested that I run the stock setup that comes from the box.
#65
if you go on the top web site you will find the part numbers and what they are from and some proper trick red bis the gold looks pretty horrific if you ask me.(just my opinion)
#66
#67
It also uses Yokomo bits so it like 3 cars in one but after seeing how it handles on rubber. It a Frankstein weapon
#68
Originally Posted by stuey
wow is that the biggest esc ever
#69
thats a Tekin for you, but it the best ESC for stock racing. Just so punchy
#70
stuey- the gold alu parts don't look that bad, trust me!
luke-what sort of track do you want a setup for?
Last Sunday was the 1st round of the Carpet Masters series, held on a fast, but tight track, meaning any trouble with traffic could really cost you some serious time. My car was handling very well in 19T but I had trouble with traffic in my first (and best) run. Even after losing half a lap ( ) I was 4th after round 1 behind the likes of Olly Jefferies. Unfortunately, continued problems meant I didn't improve, and everyone else did meaning I ended up qualifying 12th. Even so I was very happy with the car, and it is improving rapidly
#71
just returned from the indoor schumacher carpet series in which i tqd by some 2 secs the car was awsome very easy to drive, in the main made a few mistakes and finished 2nd overall, the competion was tough as the whole schmacher team was there, the scythe proved to be the bast car there it also set the fastest lap of the day
set up will be posted soon
thanks jimmy maddison
#72
shock building
Hi Jimmy,
Well done, you seem to have the scythe going very well, i was 3rd at the BIWS behind you, and your car seemed dialed! and very smooth. Just built the scythe, and built the shocks as shown, seemed very hard and even borrowed some softer springs, car was very bouncy. In the bottom of the shock it said to put the red rubber seal in folloed by the black spacer.
Did you build the shocks as instructed or have you any tips on building them? also what weight oil did you use, i used 30w and seemed hard.
Thanks Luke Humphrey
#73
my shocks are per kit i run 2 hole pistons with 50wt all rnd, yea the car is awsome im running 19t and 27t at the next BRITISH INDOOR WINTER SERIES
jimmy
jimmy
#74
ok, ill try that, please can you help me set up wise at BIWS2 so we can have scythe 1st and 2nd lol please???
#75
Luke, they are fine built standard. 30wt isn't hard at all, Jimmy and I have been running oil around twice as thick as that with no troubles. Are you sure the shocks are built right as it is easy to trap air in the Yokomo shocks when not built using the correct "technique" Have a look at the Yokomk BD instructions on the CML website for better information on how to build them.
