T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 12-11-2007, 03:21 PM
  #616
Jamesalex's Avatar
hi just a quick question may be buying this car so what is the ups and downs spares etc i should look at carrying spare.
And whats best for 19t and stock 27t rubber carpet/tarmac, a spool or diff?
Jamesalex is offline
Old 12-11-2007, 03:22 PM
  #617
Jamesalex's Avatar
O and what sort of spur/pinion range would i have to carry in either 48 or 64
Old 12-12-2007, 12:26 AM
  #618
razzor's Avatar
double post.
razzor is offline
Old 12-12-2007, 12:27 AM
  #619
razzor's Avatar
If you getting a kit the extras id suggest is a spool which is a must have in my book, a spare set of belts as well as spurs.(102 spur std)
I much prefer the std Scythe kit compared to the ally kit for asphalt.
For the plastic base kit a set of bulkhead top peices for the shock mounts.
a few toe plates for tuning.
The suspension parts ie a-arms uprights etc.. are all cyclone/Pro4 parts so should be very easy to get.
27T stock gearing is in the 28T - 35T range with 64 pitch.
As for shock pistons the std ones are great and for better feel i have drilled the holes to 1.2mm and use 45wt GS oil.
Std springs are working well for our tight asphalt track but TOP has a a neat spring kit you can by with a selection of 12 pairs alternative is a TeamMagic spring kit.
So far over the last 8 months of running the Scythe i have rebuilt a diff and replaced the bulk head tops once after some exhuberant driving.Other than that car has been very durable and reliable.
This Saturday im running it in a 6 hour enduro so will see how she takes that abuse.
razzor is offline
Old 12-13-2007, 02:10 PM
  #620
Jamesalex's Avatar
Post
Is there any build tips or issues that you can point out when building an 07 or 08 model?
What make and what type of springs are best/most used on this car?
Does anyone have a set up that is good on carpet med traction rubber tyres?
What would be advised when running a 19 turn motor and a 27 turn motor, spool diff etc?
Cheers
Old 12-14-2007, 01:17 AM
  #621
razzor's Avatar
Have you downloaded these :
Scythe Instruction Manual (Rev. 2)
http://www.top-racing.jp/UploadFile/...2125634591.pdf
Scythe Assembling Addendum
http://www.top-racing.jp/UploadFile/200632211214422.pdf
Car goes together well and i would suggest you get some shim sets to take out slop on the wheels and hinge pins.
razzor is offline
Old 12-14-2007, 01:19 AM
  #622
razzor's Avatar
For 27T and 19T i would recoomend you get a spool as a option for tuning at your local track, i prefer it to the oneway.
For springs try the std ones first they are not bad at all for that matter try the std setup and take it from there. I was surprised how close the std setup was to how i like.
razzor is offline
Old 12-14-2007, 09:19 AM
  #623
hey guys i just thought id let you all know i will be running the scythe as soon as i get it here so any tips would be appreciated thanks later jason
ERTRACHTER is offline
Old 12-14-2007, 10:09 AM
  #624
Trader Rating: 40 (100%+)
Great pick up TOP.....Now lets just see if Jason can get a Win at snowbird...
King of B Main is offline
Old 12-14-2007, 11:08 AM
  #625
i think a win is in my near future i got stock rubber in the bag
Old 12-14-2007, 04:36 PM
  #626
Try tuning with sway bars rather than spring rates. The stock springs work well.
Dragonfire is offline
Old 12-15-2007, 06:37 AM
  #627
Trader Rating: 15 (100%+)
Not if i go but you and ej can fight for second!
AARON YOUNG is offline
Old 12-15-2007, 06:56 AM
  #628
i know i've seen how you've done at the big races before i dont think i have to worry about the blow out king
Old 12-15-2007, 10:30 AM
  #629
STLNLST's Avatar
Trader Rating: 32 (100%+)
Too funny.
STLNLST is offline
Old 12-15-2007, 03:22 PM
  #630
I know i should just get high so im not nervous.
