Foam tyre TC setups
#31
Suspended
I will use Matrix to My 4wd TC 1/10
I have
2pc 30mm 40shore
2pc 30mm 42shore
2pc 26mm 40shore
2pc 26mm 38shore
I have also two more pair. one 30mm and one pair 26mm i have forgott shore on these.
How do you guys run Matrix foams ? Any sheet or rekommendations?
Long time last i did asphalt track with TC
38shore is more soft than 40shore right?
38shore has more grip than 40shore ?
I have
2pc 30mm 40shore
2pc 30mm 42shore
2pc 26mm 40shore
2pc 26mm 38shore
#32
R/C Tech Elite Member
I have
2pc 30mm 40shore
2pc 30mm 42shore
2pc 26mm 40shore
2pc 26mm 38shore
I have
2pc 30mm 40shore
2pc 30mm 42shore
2pc 26mm 40shore
2pc 26mm 38shore
As I posted in your other thread:
Lower number = softer = more grip = used on lower grip or cooler surface = higher wear
Higher number = harder = less grip = used on higher grip or warmer surface = lower wear
