Xpress Execute XQ1S Sport Clubracer
#692
What is everyone doing to get the slop out of the wheel?
It’s more the axle/bearing. I installed the associated axle spacers ( as previously shown in this thread) between the bearings but it hasn’t changed at all.
any tips ?
any tips ?
#694
#695
Try a 0.2 mm shim first, then maybe use 2 per wheel. I just did this. I installed 2 and it was too tight, but 1 shim was too loose. I replaced the bearings and that helped tighten it up a lot with just one shim. Overall I have one shim per wheel, on the driveshaft side. Also take your pinion off for a last test of freeness; should still roll smooth.
#697
I finally got to run mine on carpet last weekend.
I picked up the xq1s kit plus the mid mount kit added sway bars and wheel hexes for ease of tire changing. Pretty cheap setup under $300AU
I was super impressed from the first moment of hitting the track . The initial turn in is fantastic and the overall balance of the car is great.
From practice through the 3 quals and 2 finals the car was super consistent.
I was running the same lap times but with Much better consistency than my destiny.
I was sceptical that anything this cheap could be any good.
hopefully I will get to run it on asphalt soon.
#699
Thank you racevta for the parts, I got them in today!!!
I'm curious how about the powerstar servo, it's still in the package but the specs look great even at 6 volts. I'm currently using a helicopter cyclic servo and it's so slow (.13) that I have to start turning into the corner way too early.
#700
#701
Antenna holder
Does anyone have any ideas for the antenna? I still have the tube but the base broke off. How can I just rig it?
#703
Fixed.
I found another antenna holder in my body posts bag.
New radio system (DX5c) and Powerstar servo, ready for Sunday race.
#704
Servo Turnbuckle Contact
I’m a rookie and recently bought an RTR XQ1S from someone at my local track. The car runs great, but I noticed the turnbuckle connected to the stock servo horn contacts the upper deck when turning left and limits full travel. After doing some research it looks like all the Execute steering linkage setups have to potential to do this out of the box. I noticed 3Racing Sakura kits include an offset ball end cap that lowers the turnbuckle angle a few millimeters.
Has anyone else had an issue with this? If so, did you change parts or simply adjust the servo EPA? Would installing a servo saver lower the linkage enough for more clearance?
Thanks.
Thanks.
#705
Thanks.
Thanks.
