Xpress Execute XQ1S Sport Clubracer
#631
Is this chassis comparable "Competitively" to a 2015 T4? I keep seeing people talking about how the X1Q0 is alot better than this, since it is the "competitive" chassis and this being the "club racer", Was wondering how well it was compared to something like a 5 yearold T4
#632
I've also got the XQ10 and it's definitely a nicer car, but my lap times aren't really any different between the two cars in the stock classes.
#633
if using indoors on black Carpet u need alloy chassis as it seem a must for any car but u have to upgrade to xq1 motor mount if u did that
#634
Sweet, Thanks guys.
I'm asking because I currently run a '15 T4, and I've been eyeing this chassis for a while now, not sure if it's even worth it since I already have my T4.
Plus parts for these out in Canada is just a nightmare since the american dealer went out of business.
#635
Hi folks. Finally got my xq1 s (pre built version was all that was available). Went thru and freed everything up. Having an issue with strqaight lines. Best way I can describe it is its like torque steer. tracks straight when checking, but on power wanders one way or the other. Been told it may be the crappy servo I have in it. good #'s but just a cheapy. On a really tight budget, but springing for a new one this week. Team Powers low profile HV I think it is. Have had one of our top drivers drive the car, and altho he made it look much better, could see there was a prob. Any help would be appreciated.
#637
check for any binding as well. Pull belts off and see how free car is. Should be smooth all the way around also servo could be but anything too tight could cause as well
#639
how do you guys find the diffs? do they leak, do they need to be up dated? any seals need to be changed?
#640
#642
Recently I bought some 64dp 90 teeth spur gears from different manufacturers, just to see which ones are a straight fit.
Axon DTS and Panaracer spurs went straight on, Arrowmax, Tamiya and Xenon are too thick.
Result: you need a spur gear with thickness of max. 2.5mm in its center area.
#643
#644
New question for the group. will the xq1 steel double universals(10166) fit the xq1 s? I understand just one bearing needs to be changed to a 5x10x3. or will I need the spring steel universal? Are they the same just different material? BTW savox 1258 tg fixed my wandering prob. car is getting awesome
#645
nearly every tc but one or two have the 5x10x3 bearing
the difference is ones stronger the black ones are ok but new ones are very strong (why they are fitted to ft1 fwd as takes all the load)
