Imprecision on measuring sensor board deviation
#16
Well most of this technical data has gone over my head, but the basic commutations and accuracy/repeat-ability, temp stability concepts make all the sense in the world. Just for an intellectual exercise, wouldn't accuracy be improved if 6 sensors were used and each pair were averaged for each rotation? Are esc electronics capable of calculating that average in time to make it useful?
#17
Maybe? to what end? What would provide better precision, is using jigs to glue down the components before soldering.
You could do averaging... But if you've got a 32 bit micro on the ESC, you can just "do the math". You know the poles of the stator are 120deg apart, the poles of the rotor are 180deg. The motor could outpulse a standard rpm.. and then easily measure the deviation from the norm and build up a compensation chart.
Adding more sensors, really just puts you in the bucket with "are these in a good place too?" So math and calibration might be the thing in order.
I'd need to look at the ROAR rules more closely, but I suspect using synthetic timing events would get you outside of the Blinky rules.
I'd go back to a Jig I think. That is probally the best option, and it's ESC independant.
#18
Very few rotors have the poles within 1 degree of 180 apart. Good rotor symmetry is one thing that guys will pay extra to get, as it improves performance. Bad rotor symmetry will throw off the timing calculations of some motor analyzers.
#21
Totally not something i'm gonna do. But there ya go, a way to sell better ESCs.
#23
All the newer rotors I have are between 0-2* assymetry.( Motiv, Reedy, R1)
All the old geneation rotors I have D3.5/4 are 4-8* and with one tuquois ht at 37* assymetry . I never
could use it. Never new why It made the motor run like cr*p until I checked when I got the motolyser.
#24
