wtcc's FF project >
wtcc's FF project
Like Tree424Likes
wtcc's FF project
Old 11-14-2022, 07:42 PM
  #391
It's not as personal attack. I lament that the sanctioning bodies don't prevent well-funded and/or technically savvy racers from developing cars that subvert the intent of the class and/or price out ordinary participants. You're being a competitor, and you're not being restrained. Not your fault.
The FF class should be front-heavy with limited forward grip. It should be a substantially different driving experience from the other classes.
Now that the sanction is allowing other production mid-motor race chassis, it'll never again be what was intended. That's what I lament.
Masami Halsey is offline
Old 11-14-2022, 09:45 PM
  #392
Car is looking very good...
bertrandsv87 is offline
Old 11-15-2022, 03:58 PM
  #393
The rules are pretty clear, and there never was anything about weight distribution in them. It's only your opinion.
mr.rev is offline
Old 03-19-2023, 03:41 AM
  #394
luppix's Avatar
Some news for this Amazing Car?😋
busman likes this.
luppix is offline
Old 03-22-2023, 12:00 PM
  #395
wtcc's Avatar
luppix Sorry, nothing new happened to bring this car on track. I worked a bit more on the CAD data and optimized geometries, but that’s about it. I haven’t giving up, but the costs for part manufacturing aren’t motivating…
But I can show the work I did. I mostly worked on the MF variant. I mostly despised the position of the servo in front. The Ackermann wasn’t a problem though. I just don’t want the car to be long in front and space for a bumper (this design might change in the future). So made these extensions for the classic servo position. Also changed are the servo mount, all hubs and the damper setup. The car is now optimized for XLP dampers. This included all mounts and the lower chassis plate:
wtcc is offline
Old 03-22-2023, 02:08 PM
  #396
Looks sick. Do you have a close up straight above the dampers in the front? orthographic perspective preferably.
MatsNorway is offline
Old 03-22-2023, 10:18 PM
  #397
h2e
h2e's Avatar
make sure you have a way to keep your bulkheads positioned. Reading through the IRIS thread they seem to have issues after crashes. so keying or special screws like the AMX A800R.
wtcc likes this.
h2e is online now
Old 03-23-2023, 05:32 AM
  #398
h2e
h2e's Avatar
And in case you need more front weight bias, you might want to mount the esc on top or into your bumper? The ARB wire would need to go a bit lower maybe, but should be doable. I imagine that will be beneficial over adding heaps of ballast to the front...
wtcc likes this.
h2e is online now
Old 03-24-2023, 11:38 AM
  #399
Why not just make a simpler rear? so much fancy suspension stuff in the rear. Is it really needed? Does the weight outweight the benefits of a lighter rear.. Say swingarms and single damper with a roll bar. Or Yokomo YF? with all the stuff up front almost.
Eotz and h2e like this.
Old 04-23-2023, 06:07 AM
  #400
What are the front driveshafts your planning on using?, they look pretty short. Custom or something off the shelf.
Atomic-Carbon is offline
