Yokomo MR-4 TC Thread
#1696
is anyone having trouble with thier diff's? for the past couple of weeks ive been fryin the rear diff in about 3 runs and durring every rebuild i would always put new parts, whats going on?
#1697
can I interchange trf shocks with the mr4???
#1698
monkey - probably, i would measure each first to check.
Chris - Make sure you don't tighten it up too far, just enough not to slip.
Josh
Josh
#1699
there threaded, what size are the mr4 shocks anyone knoe?? I want to see if I can put my adjustable shocks on the mr4 custom cuz I want a new car but dont want to spend alot of money. (like under $200 for everything ...esc, motor, controller etc...) I found a mr4 custom for 97 alone, and 200 rtr (havent found out which radio).
#1700
The MR-4 shocks are adjustable from about 58.5mm to 64mm in length depending on which shock ends you use.
Josh
Josh
#1701
I noticed that mine tightened up after I rebuilt it. I rfeadjusted it and it hasn't done it since, but it was weird.... the rear of the car started to get loose on power and that's how I found the tight diff. If I hadn't been looking for a reason that the rear was feeling loose, it probably woulda smoked that bad boy.... :~
#1702
hey yall and whats up speedo we have talked on yokomousa.com. enyway to busyness
i got a xxxs recently and i use to have a yok i dono which is better and i also wanted to know about
i was thinkin about gettin the new yok over the summer but when is it commin out and is there "realy" ganna b eny "real" improvement in performance cuz i dought it could change very much but it does look rad i want to have an xxxs and a yok i like those to cars the best, i kinda think the yok is better in a scence bcuz it is more ajustable ya know? respond later
this is (cs) Crzy][ako;:"eeko signin off
if you race at so cal talk to me on my AIM s/n is> mats8ergt and you can contact me at [email protected] if you have seen a guy name bumpity bump dats me im out peace <<<< hahah im such a kidder later
#1703
Bumpity, how is the yok mr4 more adjustable than the xxxs?
#1704
The yok has more camber rod options, you've also got the option to run the front camber rod on the kingpin or inboard of it. The Ackerman is adjustable on the Yok, and the bulkheads have high and low roll center hingepin locations without the need to change parts. THe front caster blocks and the rear hub carriers on the Yok also have high and low hingpin locations where the Losi doesn't.
Trips
Trips
#1705
Trips, yeah but how many caster blocks does the yok have? Stock is 5. I know team suzuki makes a 3. The XXXS has 0, 2, 4, and 6 degree spindles. What about kickup and anti-dive for the yok-that bulkhead is nonadjustable. The Losi can have anti-dive to kickup in the range anywhere from -2 to +4 giving you more than plenty of total caster options. Rear toe? I only know of the yok having 2 differant options. The xxxs has like 3 differnat rear toe hubs plus you can mount 1 backwards. What about anti-squat? I know that's not adjustable. The wheelbase isn't adjustable either, The xxxs has adjustable front and rear. Underdrive? Overdrive? Does the Yok has 2 camber locations on the rear hub for the camber link? Whatabout battery locations? And as for roll centers, you are correct that you'll have to change parts but what's wrong with that. On the xxxs you can have a fine degree range of roll center like the anti-dive/kickup by using washers under the blocks. Here's the best one- that yok don't have droop screws. Guy, I don't want to sound like I'm dissing yok but I've owned all the cars back to the YR4 and I like em.
#1706
Oh and I can Overdrive or Underdrive a 1-way
#1707
Also, the xxxs has 5 differant shock pistons along with 10 differant springs.
#1708
Plus the xxxs has 4 differant sway bar thicknesses for the front and rear.
#1709
PW-
The Yok has 3 castor blocks- 3.5.7
Antidive front or rear isn't that important of an option IMO.
Rear toe- 0,1,2 hub carriers
Wheelbase IS adjustable.
Over/under drive- what a joke- nobody even uses it.
YES the Yok DOES have 2 camber links o the rear hub.
Droop screws- I agree.
#1710
Agreed. No kickup and anti-dive adjustments on the Yok.
The Yok has three available rear hub carriers, 0, 1, and 2 degree. You can mount one of them backwards as well.
The anti-squat is not adjustable, the wheelbase is.
Agreed.
Yes it does.
Just one battery location.
Nothing "wrong", but Losi doesn't include or even sell the parts to allow roll center changes. If you don't want to take a dremel to the stock parts you've got to buy the Trinity MF parts or some other aftermarket parts to get that adjustment.
Agreed.
I'd give you that one too, but the Losi doesn't have -working- droop screws. Yeah it has them, but they're set in the soft bumpers and they're so close to the hingepins that they're essentially useless. I had to set the droop on my Losi the same way I do it on the Yok, with shock length. Associated and the Euro-cars like Corally and Xray have good droop screw setups, I wish the Losi and Yok did too. Changing shock lengths is a PITA.
No problem, both are great cars, neither is perfect.
Trips
