Carpet Off Road Tire selection
#46
You can buy narrow wheels of you don't want to cut them. I've run wide front wheels without cutting them too. Looks funny, but it worked just fine.
#47
Has anyone ran Schumacher blue compound rears on carpet? Do they last longer? I was thinking about getting some practice tires.
#48
on the turf track in our area, the yellow compound tires are running more consistent and actually lasting a couple race days longer than the blues where blues might go 4-6 race days and yellows are lasting 6-8 race days... things might change as temps heat up and we hit summer months with the turf track in our area being covered but outdoors.
#49
We run a tight indoor track on carpet. I was just thinking they may last longer for practice. But you don't make it sound appetizing haha
#52
Where do you find green compounds?
Here is the current color chart posted on AMain, I have not tried Silver because the track in our area is on turf, and nobody likes to run their 1/10 cars on the adjacent 1/8 dirt track... shrug
The track recently started an Oval program and I saw one guy running Yellow Cactus with decent results, I can only imagine that Silver would do phenomenally better!
#53
There used to be a green and an orange compound back in the days before astroturf. IIRC orange was ultra soft and green maybe a bit harder than yellow, but I am not sure. All I remember is that we did not always use inserts back then because most tires were so hard you would not need them. Now I'm feeling old again...
In my experience tire wear is subject to the type of carpet you race on and track layout. Some years ago, Model Indoor Oss used carpet tiles and you would need two or more pairs of Minipins per race day. After they switched to EOS carpet, your one set of mandatory race tires would last for several practice days. I found JConcepts rubber wear better than Schumacher tires and work pretty well on carpet, but the Pin Downs buggy tires were much slower vs Schumacher due to their high profile. On stadium truck, they are my go-to carpet tire. The ST Proline Prisms Z3 did not generate enough grip wheras the Wedges would engage the track markers too easily and ruin lap times. They worked pretty good on Astrturf together with the Pyramids, though, and seem to have a very good wear rate. I can't wait to see how the Nessi performs on Astroturf. I'd be ok with slightly slower lap times as long as I'll get a day or two more out of them compared to the Darts.
#54
Green is a wet grass compound. Don't think they sell much these days!
#56
In the UK we get about 2 runs (yes 2 5 minute runs) out of a set of rear Mini Dartrs in 2wd mod (only really mod racing in UK). After that there is still life in them but they are 1/2s per lap slower or more depending on how much forward drive the layout demands, most tend to put them in the box for practice days after 2-3 runs.
Nothing else out there lasts any longer either (new Proline tires might, yet to try them).
I've no idea how you get 6 days of useful out of a set.
#57
6 race days .... WOW
With a brand new set of tires, my car feels twitchy (over responsive) to where I dial back the steering speed to around 90% to make the car very easy to control, then each following race day, I'll increase the steering speed by 1% increments to account for tire wear in order to maintain my hot lap times where somewhere between 96%-98% steering speed is when the lap times start to fade and the tires need to be replaced then reset the steering speed back to 90% again.
Here's a sample run to give you an idea of what the level of traction I was getting with some tires that have seen about 12 runs through them and steering speed at 93% or roughly half worn Schumacher Cactus Yellow's:
*** It's worth noting that I am running 4WD stock 13.5T which are 2 contributing factors to longer tire wear.... 13.5T motors are significantly slower and don't wear nearly as fast, plus 4WD cars tend to offer almost double the life of the 2WD 17.5T stock buggies... excessive tire wear on 2WD is the main reason I chose to only run 4WD classes... in fact my TEKNO ET410 will get about 15 race days on a set of ProLine Wedge/Pyramid ST tires in Z3 compound
#58
Anyone tried the hobao hyper tt tires on carpet? They look closer to a Double Dee copy than carpet tires but for the price I was considering trying a set.
https://www.ebay.com/itm/Hobao-11109-Hyper-10-TT-Off-Road-Truck-Tires-w-Foam-4-OFNA-21247/392126160847?epid=4023883713&hash=item5b4c8a5fcf:g :i94AAOSwF2FbpTGt:sc:USPSFirstClass!28277!US!-1
#59
My local crc black carpet tracks only allows slicks like the Proline Prime (clay compound).
#60
