RUSTLER NEED HELP
RUSTLER NEED HELP
What's up guys! NOOB here ha I recently purchased a rustler vxl my issue is when I hit the trigger to go sometimes it will stop and I have no response until I turn the car off and back on again. Sometimes this will happen 2 3 times b4 the car responds correctly any thoughts/suggestions are appreciated thx guys!
You could be hitting thermal shutdown.
Are you using the battery that came with it or a lipo? Esc might be set up for lipo and if your running a NiMH you hitting the low voltage cutoff.
Yea still running the nickel battery I've checked the setting and it's correct. I have lipos ordered I'm hoping maybe it's just a battery issue
I mean unless I'm completely retarded ha Ivery read the manual on the setting for nickel battery and lipos it also came set to run that battery says the light should be solid red on the esc
Yes red for nimh and green for lipo
Keep us posted. Curious to see what it is.. so light on esc is red ? Since ur using nimh? Make sure u set the lipo cutoff when u get ur lipos.. green light on esc
Yeah, if its brand new, take it back for warranty.
I'll def let yall know I'm going to contact traxxas tmrw. YES light is Def red YES I'm using NiMH battery
So I got in touch w traxxas today he sending me a glitch buster like one of the other members mentioned he said basically the nimh battery isn't able to supply the power the car is demanding so it's sending false nominals like the battery is dead therefore I lose response. Guess we will see I've got new batteries on the way also
