Tekno RC EB410 Thread
#4009
And for anyone else wondering, I asked and had it confirmed by a team rep, all of the team guys are running 1.7x2+0.8x4 machined pistons up front and whatever their choice is for the rear, 1.8x2+0.8x4 or 2.0x2+0.8x4 etc., they all run the 4 smaller relief holes.
#4010
And as for feel, well I had two different experiences. The first was running those pistons with the stock bottom cartridge setup. And it helped flat landing jumps a little bit more keeping any sort of donkey kick mostly subdued. The 2nd time I tried that same setup using the new MIP cartridge and while it helped in the same areas, it was more consistent and the rear seemed a little more supple and soaked up the bad landings even better. It also seemed to help with high frequency bumps keeping things a little more planted on the rear end. We have a chicane in the center of the track that has these offset bumps that can throw the car off center, but this time I felt I had more control to give it more throttle through that part keeping up speed for the next corner which was key to hitting the triple with enough speed.
#4011
Tech Legend
They are 0.8mm.
Right now we have jumps here that in general you flat land. The vehicles will bounce a bit because of this. wondering if going back to 1.8 x 2 with the 0.8 x 4 hole setup could give back the pack I want but still handle some of the bumpier sections of the track better.
And if so, what oil ranges are they using with the 1.8 x 2 hole setup.
#4013
They are 0.8mm.
Currently my car has the recommended setup on it. I recommend this to everyone on Clay with a center diff. If you have the slipper, you'll probably need to tweak all of the setups listed on our site.
Brian Bush should have some good slipper setups for carpet on Petit RC too.
#4014
did they happen to say what conditions they went with for the rear piston setups (when they would use 1.8 versus the 2.0?)
#4015
Haven't got to run it after my changes but shaved some weight and added some back on where I think is appropriate for me and got nice lean 1633g RTR weight.
Can stay almost the same weight by removing the 40g exotek weight and adding full size lipo...it just shifts the weight more forward then, depending on what I am looking for at the time. Also replaced all of the titanium screws on the rear underside of the chassis back to stock, to get more weight low and in back.
Hopefully get to run it this week and see how it handles after it's weight loss program!
(Don't mind the food waste bin..LOL)
#4016
For those of you wanting to convert to a 2wd, I just saw this.
Coast2CoastRc Tekno EB210 2wd Conversion Kit Thread
#4018
It kinda reminds me of the original 22-4 1.0 body. I like Exotek stuff but it's not for me. I ordered the Raw Speed body a while ago which I thought looked really good online but in person I found the cab looked really small and narrow making the main body appear larger than it really is, so it's sitting to the side. The JC body makes it look like a B64, so forget that noise! But it may get my money. Stock for now I guess
#4019
I see what you are saying, I keep looking at it and like it less each time myself...the LFR body has been more appealing IMO. Stock one has definitely grown on me.
#4020
