Tekno RC EB410 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree2421Likes
Last edit by:
Print Wikipost
Old 02-20-2018 | 08:56 AM
  #3766
vwduud's Avatar
Originally Posted by Reno
Turn on tx and rx then place buggy on flat surface against a wall. Then take your camber gauge and measure each wheel against the wall to see what degree it is.
This method will also get your wheels squared up. Make sense?
I modified my pit board years ago, by adding a vertical 1x4" board at one end. I inserted 2 short 1/4" dowels into this 1x4, drilling corresponding holes in the pit board to easily install and remove. Gives me a "portable" wall in which I can measure the toe in/out easily (at home or at the track), using my camber gauge.
Is interesting when you ask someone their toe in/out measurement. Typical answer is "2 or 3 degrees toe out, per wheel" (in 1/8th scale). I put their car on my pit board and measure it. Not only is more like 4 to 6 degrees (sometimes more), rarely are the measurements equal from left to right wheel.
How many settings on setup sheets are based on "best guesses" vs. an actual measurement?
ezlight likes this.
vwduud is offline
Old 02-20-2018 | 09:04 AM
  #3767
Originally Posted by EbbTide
Nope (not as a free replacement). If you break the pins or the bulkheads you still get a voucher for 50% off the new part. The only other way I'd imagine Tekno would send you a part for free is if it was missing from the kit or defective and not usable. The hingepins and bulkheads weren't defective, they just didn't hold up to the abuse some folks were putting them through and Tekno wanted to make it stronger without adding too much mass.
Ok cool...just thought I would ask. I'm using titanium ones from rod stock I ordered and are working fine. Ive only bent two OEM hinge pins since owning the car and they were slight bends. for what its worth Ive never bent any in my Xray or Losi. My daughter now drives my Xray 2017 and no bends...and shes not easy on it either. thanks
AJrollin is offline
Old 02-20-2018 | 09:16 AM
  #3768
EbbTide's Avatar
I hear ya bud but at least they are making the rolling updates so people don't have to wait for the eb410.2 to get the extra beef. I am not easy on my car either and the only bends or bulkhead breaks I've had were clipping pipes at speed or slamming into a wall after landing a double in a bad way. So everyone's having different experiences and an xray that has been updated over the years is kind of a bad comparison for a buggy like the eb410 that is brand new to Tekno and the RC industry. Growing pains are assured
EbbTide is offline
Old 02-20-2018 | 09:44 AM
  #3769
So free front hinge pins for all?
Originally Posted by RazorRC
No
My kit was first run, and still on original hinge pins, and she see's some spectacular crash's....
ezlight is offline
Old 02-20-2018 | 10:03 AM
  #3770
Cain's Avatar
Tech Legend
On my kit here seen 1 hingepin bend, it was a pretty good hit from a guy going the wrong way down the straight with a 4x4 SCT.
ezlight likes this.
Cain is offline
Old 02-20-2018 | 12:04 PM
  #3771
dtr's Avatar
dtr
Is anyone else getting http 403 errors when visiting any teknorc web page?
dtr is offline
Old 02-20-2018 | 12:08 PM
  #3772
negative
ezlight is offline
Old 02-20-2018 | 12:09 PM
  #3773
sickpuppy1's Avatar
nope
sickpuppy1 is offline
Old 02-20-2018 | 12:32 PM
  #3774
proliteandsc's Avatar
Default Another shock question
Read earlier that you should bleed shocks by removing bleed screw, compressing shock, and then putting screw back in. Won't you sucks in dirt from around screw if that shock still has lower pressure inside then outside? Would it be better to slowly compress shock and then open the bleed screw?
proliteandsc is offline
Old 02-20-2018 | 12:53 PM
  #3775
Reno's Avatar
If you want oil in your eye! LOL!
boudin4evr, ezlight and Tbuggy like this.
Reno is offline
Old 02-20-2018 | 01:25 PM
  #3776
Growing pains ...no problem, in fact I think Tekno has done a great job for the first time buggy in this class, its just the handling of parts in question, like the front bulk head for example, they make a slightly stronger one to use in place of the stock weak one but its the same part, and call it an option part??? Most other companies would just acknowledge a design issue and fix it, replace and keep on truckin. I 've not broken front bulkhead, but don't really crash that much
AJrollin is offline
Old 02-20-2018 | 01:36 PM
  #3777
EbbTide's Avatar
There is always the option of sticking with the brands that operate in a way you can appreciate.
stanleyw808 likes this.
EbbTide is offline
Old 02-20-2018 | 01:40 PM
  #3778
Reno's Avatar
To be fair most of the broken parts including the bulk head are from a hard impact into something solid. Most other brands would also break in that scenario.
I saw a guy the other night barely tap a wall with a B64 and broke an arm.
In my opinion the EB410 is much more durable than most, if not all, wheelers out there. I'm not a fanboy as I also run and like AE.
Reno is offline
Old 02-20-2018 | 01:54 PM
  #3779
My kit was Pre-Prod (no boxes or anything) and I've bent the front hinge pins ever so slightly. In fact since the bend was where the arm is cut out, I saved them in case of emergency. That shows you how slight of a bend it was.
I did bend 1 hinge pin bad when I blasted someone who flipped right in front of me on the straight. His car was picked up in three pieces, so I'll take a bent hinge pin in trade.
Bob Barry is offline
Old 02-20-2018 | 02:11 PM
  #3780
I had some bad crashes with my buggy, and never broke a bulkhead. Bent 2 hinge pins. Broken a few wings, and rear diff cover. Don't think I ever heard of that braking. Still not sure how it broke.
If I did brake a bulkhead, I would buy the new one and be glad that Tekno is constantly working to improve their products. Other companies will tell you it is what it is and if you want it better then buy the next generation of that car.
