Tekno RC EB410 Thread
#2688
It’s been a dream on my B64 and fits on the 410. I feel it’s given me nice punch out of the corners compared to the center diff. Although the Tekno out of the box drives like a dream and I went faster with it than I did with my B64. I would like to do back to back testing with both once I get mine. Back to back testing on the AE I felt the slipper felt best to me and my lap time proved it.
#2689
Well, I ran the exotek spool and a 72 spur and I started at a 24T pinion and ended up with a 26t pinion. I just dropped the diff back on and the recommended gearing 70/25 seems right to me. I run a fantom V2R 13.5 motor. I hear about this 76T.... Is Tekno coming out with a 76T spur? Or is just people's wishes?
#2690
#2691
It’s been a dream on my B64 and fits on the 410. I feel it’s given me nice Pinchot of the corners compared to the center diff. Although the Tekno out of the box drives like a dream and I went faster with it than I did with my B64. I would like to do back to back testing with both once I get mine. Back to back testing on the AR I felt the slipper felt best to me and my lap time proved it.
#2693
Are there any tracks near PDX someone could recommend to me? I will be heading down there next week for work and I am going to do my best to find a little extra time if there is something near by.
A lot of old websites from old tracks but not sure which ones still exist? Typically I run @ Tacoma RC raceway (which is clay). All I am looking for is something to do for fun while I am down there nothing serious. Even if its carpet and I am not set up right I will make the best of it!
#2694
For anyone that wasn't at SDRC to get the first run of the MIP Pucks, you can now buy them online at MIP The price is better than I first thought.
MIP 13.5 Performance Bundle Package, Gear Diff, Tekno EB410 #17150
#2695
R/C Tech Elite Member
#2696
Pics
Not sure if this has been mentioned or not but as I was assembling the driveline I noticed the center front and rear driveshafts had a lot of movement in the outdrives so I remembered a trick from the carpet racing tc road course days and that was putting o-rings in the outdrives to keep the driveshafts from sliding back and forth making noise plus keeps the driveshafts and outdrives from getting all worn out there AE O-rings part#5407 but let me know what you guys think about this lil trick.
Second tip trick is the Tekno CF steering top plate doesn’t come countersunk for the flat head screw so you can get a countersunk bit for a cordless drill or dremel and do it yourself fairly easy just take your time and then seal it with some CA Tire glue on a q-tip and I swapped out the 3x6mm screw for a 3x10mm FH screw
Third thing for chassis protection the protek universal is a perfect fit after a lil trimming I cut out holes for the screws do to the need to access the screws for diff changes that are going to need to be serviced and tuning purposes the amain part # for the protek chassis protector is PTK-1102
