Team Associated RC10B64 Thread
#3032
Still running the 10° caster blocks. Tried messing the with the A&B blocks kickup to add more caster but never really got it setup well. Went back to kit setup for A&B and it runs awesome. With less kickup and caster it corners nice and flat without too much dipping off throttle or under braking. The 13° caster blocks will make it more stable and less twitchy while steering.
#3033
Did some testing with the center diff oil for 13.5 on clay and ended up at 30k. Sounds stupid but it now carries more natural mid corner speed, don't have to hustle the buggy to go fast into and out of corners. Using a softer/grey front spring to keep the front from lifting as much on throttle and a stiffer swaybar on front to prevent the front from rolling as far off throttle.
Have tried 500k, 200k, 100k, 80k, and now 30k. I most often ran 100k or 200k but noticed the back end had a tendency to step out if I wasn't careful on the throttle in a corner. When I switched to 30k it didn't lose any acceleration which seemed weird to me. It only got more stable on throttle in a corner and carried a ton of corner speed off throttle. I could get on the throttle sooner in the corner as well.
Also running the outer hole on the rear arm to keep the back end from squatting as much.
Front 10k diff, 3x1.4 35w, grey spring, blue roll bar. Rear 7k diff, 3x1.5+1 32.5w, green spring, grey bar. Steering D/R turned down to 80%, +2 steering plates. Buggy feels like it's on velcro
#3034
Good to hear. I wondered how that would work but I get little enough track time that I was reluctant to try it. Let us know what you're seeing for front tire wear.
#3035
B64D center to front driveshaft binding
Hi all, I just got this kit and was hoping someone could help me out if they’ve run into this. I have a weird binding in the drivetrain, it doesn’t spin freely. I found out why, but have checked everything and can’t see anything wrong. Here is a vid I took showing the issue. There is such a tight fit that when the dog bone spins on the side where that “c clip hook” is, it pushes the whole front diff case forward and flexes the chassis until the next revolution.
Copy and paste this link: https://youtu.be/QUZHmUMY9XE
#3036
From the video it looks like the dogbone is OUTSIDE the C-clip, you want it inside the outdrive past the C-clip. Take the center diff out and put the dog bone in at an angle past the C-clip, reinstall center diff.
#3037
The dogbone isn't inserted into the input shaft correctly because its hung up on the retainer ring. You want to insert the dogbone into the input shaft first and will probably have to insert at an angle to clear the retaining ring. You inserted bone into the center diff first and the bone can't clear the ring when you install it straight on. when installed correctly, there will be plenty of free movement in the bone and no binding.
#3038
13.5 expert driver of the night was at 15.630 fast lap and top 5 avg 15.7, top 10 15.8, top 15.9 to put it into perspective.
100k test
80k test
30k test with blue front swaybar and grey front spring
100k test
80k test
#3039
#3041
need some help with gearing. Running the exotek eliminator with a 75 tooth pinion gear and a 13.5 team scream motor.. What pinion do you guys recommend ?
#3043
The arm breakage is there. No poor build or any other finger pointing back to the driver. The HB and Losi didn't break in the same race conditions. I've been racing long enough to know an issue when I see one and a couple of local team driver's experiencing the same.
I've broken the hard and the kit arms in the front only. The buggy is amazing though. Just looking to finish some of the races I had breakages in.
And an RPM option? Really? Let's leave those for the bashers out there.
#3044
Questionable at best. I also have broken arms, but every one of those incidents have been spectacular crashes or landing/hitting a pipe at full bore at just the right angle. I encourage you to look within and think about the crashes again... maybe you're asking too much from your car, friend. Durability has never been the hallmark for AE. You know that. They make a great car at a great price, but usually comes at the expense of durability and craftsmanship.
#3045
the new arms with a little more material/bulk are way better than the original arms. I haven't had a problem with the improved arms unless I tag a wall or some other driver error.
