Xray XT2 2WD Stadium Truck Thread
#421
i found some setups here using those motors: Team Xray XT2 Setup Sheets
13.5 = 81/30
8.5 = 81/21
if you want to use that 75 tooth just do the math and figure out which pinions will get you the same gear ratios. of course this is a ballpark #.
13.5 = 81/30
8.5 = 81/21
#422
Thanks! Just gear down 1 tooth pinion for every -3 spur roughly. Helps thx!
#423
What is with the ball joints? my early hobbyking models held better. With my front ball joints I couldnt even use the tool to turn the turnbuckles without them coming off.
How do we find ball joints that will hold?
#425
13.5 = 81/30
8.5 = 81/21
13.5 = 81/30
8.5 = 81/21
Team Associated B6 & B6D - Charts - Gear Ratio & Arm Mount Inserts
#426
Does anyone cut the outer staggers off Schumacher stagger fronts? Why would you put tape around the outside edge of the tire??
#427
Thx. Just don't know if buggy gearing is a lot lower than ST
The XB2/XT2 have the same internal gear ratio as the B6 so you can use this chart to figure out your FDR
#428
#429
#430
#431
#435
When I am going down the straight I am having to wait a long time to get traction, ie it wants to spin to one of the sides. I am currently running 3k in the diff. Whats the best next step to fix this up? (besides going to dirt diff)
Thks
Ben
Thks
Ben
