TLR SCTE 3.0 Thread
#1501
Ok so the Proline Ram 2500 Flotek body states for the 4wd Ten-SCTE. Does anyone have one on their SCTE? Looking at the dimensions on the factory bodies, it looks like it is more the size of an SC10 body?
#1502
Stopped by the track to measure my stock SCTE body. It measures 11 inches. The Proline Ram 2500 shows 9.5 inches. I see people posting comments that they are using the Proline Flotek bodies (some showing 9.0 inches and 9.2 inches wide) and "they fit like a glove"? Yet I don't see anyone posting pictures of these bodies on the SCTE?
#1503
The reason you don't see people with the body mounted on their truck is that its not popular. Other designs are more sleek, lower profile and less drag.
Check the review tab at A Main. That sums it up well.
https://www.amainhobbies.com/proline...441-00/p440217
#1504
#1505
So, I've been considering this truck (again... even though I really shouldn't ). From some searching I did my understanding is that with +3mm offset wheels there could be clearance issues with the body? I'm asking because my current indoor tires as well as all but one outdoor set are with +3mm rims since my current cars are the SC10 2WD and SC10 4x4 (well actually I just got two sets of lightly used Hole Shots, but they have what looks like a +3mm Schumacher wheel, and the third set I got are the probably-0-offset Blockades since I think they were used in an SCTE).
So I'm just trying to factor in the potential cost of new wheels & tires if I can't use the existing ones - it'd be a noticeable bump in cost, though I suppose it'd be the same with the other 4WD contender, Tekno. And well, looking at the width of the SCTE I guess the car would become too wider for racing limits with the offsets anyway, but could at least use the existing wheels & tires for practise and not wear out my race set(s) immediately.
#1508
Actually I just realized that the KMC Hex wheels are apparently not +3mm, so at least one set of indoor Mini Pins should fit on the SCTE. So, I'd have enough to get started at least.
#1509
So what wheels are correct for the SCTE 3.0? I looked at the AKA premounts and it shows "wide"? None of the other brands say anything about wide? Are they not the same wheels that were used for the 1.0 and 2.0's?
#1510
The wide on AKA refers to the tires footprint..... just pick the premounts for TLR scte or Tekno 410 and you will be sorted
#1511
You are looking for +0 offset wheels or ones that will state they are for the SCTE. DE makes a large variety of wheels for this truck in different styles and colors. Also for reference any wheels that are labeled for the 22SCT (1.0, 2.0, 3.0) will also work as they are the same offset.
TEN-SCTE
TEN-SCTE
#1512
Hey guys, Hope its ok to post this question here. Im Running a 1.0 with mip kit, bulletproof diff build, dogbone center shafts and Its time to rebuild the truck. I need to replace some wore out plastics such as A arms and hub carriers etc. I was wondering if anyone knows what parts from the 2.0 and 3.0 will fit the 1.0? specifically if the 3.0 a arms and hubs will fit the 1.0. And If not what are my best bet on arms? Factory 1.0 arms? Will the bearing steering rack from the 3.0 fit the 1.0? Many thanks in advance.
#1513
Yes 3.0 arms and caster blocks will mount no problem. Rears really did not change that I can remember so good to go. Rear hubs have been updated and are stronger same geometry. Yes you can mount the ball bearing steering rack but will want to update the belcranks as well but that will all bolt on.
#1514
#1515
Should I use the ball cups Part# LOSB4023, or use the 3.0 cups Part# TLR234067, with the hard ball set. It looks to me like the only difference is the cup that attaches to the front outer carrier. If Im gonna go with the 3.0 steering setup and spindle the 3.0 cups should work right?
One other question, anyone know what BOTTOM shock caps fit Part# LOSB2834 + Part# LOSB2834. Just to clarify the cap that holds the seals in. I wanna upgrade my shocks while I am at it I still have the 1.0 rtr shocks. Will the plastic ones from my 1.0 shocks fit them?
