TLR SCTE 3.0 Thread
#1141
You don't have the custom collar adapters with 2.0 tuning springs if you couldn't get your ride height as low as 21mm font and 23mm rear, but who runs that. That modification to run the 2.0 springs with the collar adapters was tested in every way. It works. See the pics I posted with ride height around 24mm and adjustment left for up and down. Better yet, post pics of your truck showing why it wont work.
Never cut a spring. That changes the rate to something you can't reference or use.
I ran my 2.0 tuning springs. 2.0 spring perches. Black front, red rear springs. I even tried taking the stock 22 collars off and running only the adapters. Typically I run front and rear 23-25mm depending on the track design. Lowest I could get was 27mm. The additional height made my truck roll into the corners alot more. And the roll made me less consistent. I guess I should have took pictures. But at this point that isn't an option since I cut the springs down. I already pitched the springs.
#1142
Not trying to ruffle feathers here. Just wanted to give my findings. I received the collars from you. It was a pleasure to deal with you. And i received then very fast.
I can't duplicate that on my truck.
Is this a 3.0 truck?
Maybe a 2.0 with the 22 shock upgrade? Issue would be a arms, different holes.
Are shocks built with 0 rebound? Shaft stays in when depressed.
Is it possible you are running a taller tire with big lugs which increases ride height?
Lets figure it out. Something is not the same.
After some research I may see the problem. You have the 2.0 truck. You tested the 3.0 a arms and went back to 2.0 a arms. I'm thinking you must be running the 2.0 truck with 22 shocks and custom pistons. It can work if shocks are built to 3.0 spec and shocks are located further out on the arms like the 3.0 setup calls for.
#1143
Thunder Trail noted this a while back and suggest you run the 1mm longer 2.0 rear hinge pins, or the set sold by M2C here> 59mm Rear pins
#1144
Hey guys, just getting into the racing side of this hobby and ordered the 3.0 for my first SC. Thread has been helpful with all the part numbers.kit is home waiting to be assembled.wanted to ask you guys for your advice on electronics. Mixed reviews for HW and tekin but there where a few people who said they run a combination of tekin rx8 with HW motor.is that a good route to go? Most of the tracks are 1/8 and most outdoors. Any advice would be great. Excited to get into racing as I've been a basher only before this.thanks again.
#1145
#1146
You can mix and match no issues there. Tekin RX8 and Pro-4 4600 setup has worked well for me for years now and good for big or small tracks.
If you are really only running on big loose tracks may want to consider a 2 pole 4.5T motor as well. A little better top end and not as much bottom end torque.
https://www.amainhobbies.com/tekin-r...tt2243/p178468
#1147
I ran the truck first time Sat. Broke a top shock mount bolt, but just wanted to see what all needed adjusted and whatnot.
Found out the DX6R had Tekin hot-wire app already installed to help with my question a few pages back. The truck ran great lap times, handles very well and only needed a couple adjustments tightened from my building.
I put in a Mod1 14 pinion, which I wonder if I should switch out for a little more speed and i'm going to try the torque setting from 4 to 5(highest 10) as I get use to it's handling.
Thanks for all the prior posts in answering questions that makes this truck a greater truck.
#1148
Thanks thunder and Casper. Helps alot.
#1149
Hello.
im new here in this forum, just building up my scte 3.0 and I am wondering has anyone done any own modifications on the car.
I am modifying hingepin holders so I can use Tekno sct410.3 adjustment "dots" , also I need to change Teknos hingepins cause those are bit bigger. Good is more adjustments for arms, also I can make pins bit longer cause been reading that some of You had promblems with pins and that has something to do with lenght of the scte 3.0 pin ?
Mostly I am doing this mod because I can and want to build stuff. No other reason. Just wanted to share this and see anyone has done anything similar .
#1152
The largest talked about with the 3.0 is using the older 2.0 springs.
Then there is the mod where you can move the rear shocks to the front and build a longer bodied/shaft shock for the rear as well if you want full droop.
People are also moving the battery to the outside of the chassis pan which gives a more trued side to side weight bias.
You're the first I have heard that wants to run different make hinge pin braces made for another truck however, but now we can also chalk that one to the list of things done to the 3.0
#1153
I ordered my sctn 3.0 Monday has my first Electric off road truck and plan on running both a 2 cell and a 3cell set up. I just ordered a 3 cell battery so I won't see it for a week and I won't have the truck built till this weekend, my question is, can a 3 cell even fit? I was thinking the battery mount had some hieght adjustment.
#1155
