TLR SCTE 3.0 Thread
#2251
I'm using either AE srings or Kyosho springs depending on the track. Kyosho springs on bigger outdoor tracks and AE springs in smaller tracks, both work fine for me.
Front springs:
Kyosho Big Bore Shock Spring (M/Orange Super Hard) XGS023
Team Associated 12MM Shock Springs (54MM) 4.45 LB/IN Gray No. 91637
Rear springs:
Kyosho Big Bore Shock Spring (LL/Orange/Super Hard) XGS033
Kyosho Big Bore Shock Spring (LL/Yellow/Hard) XGS032
Team Associated 12MM Shock Springs (72MM) 2.60 LB/IN Gray No. 91641
Front springs:
Rear springs:
#2253
I don't think anyone has heard anything. Tlr has let the scte, 22t, and 22sct sit well after they should have gotten revisions.
Hell, they still have not built a drag racer kit, or Rtr. And that market has been booming.
#2254
Tlr Scte 3.0 setup carpet
Hey peeps
Anyone got a good setup for high grip carpet track.. It not a huge track tracks.. Can be quite twisting at times has a few small jumps kickers and one table top
#2255
Will the 1.0 Velcro battery tray bolt up to the 3.0 with no modification? If anyone has both gens of vehicles and could let me know I would greatly appreciate it. I would like to run larger range of battery sizes than what the 3.0 design allows for. Thanks, Alex.
#2257
Anyone tried the rc8b3.2 shocks? I know the x-ray and 8ight shocks work with no problems but those are hard to find on eBay while the rc8 shocks are all over the place and cheaper.
#2261
You would need something like 100k diff fluid to lock the central gear diff. It's still going to be a heavy truck compared to the 22 sct. A 17.5t is going to be able to push the truck around the track but you would still need watch the temps. I would not skimp on the esc with a 2wd 10th scale version.
P.s. https://www.rccaraction.com/brushless-motors-turns-vs-kv-rating/#visitor_pref_pop
a general table to cross referencing kv vs the number of turns. Each mfg will be a little different.
#2262
Also, might be good to start with a small pinion, like 10T or 11T
#2264
stainless steel is a softer metal. I'd upgrade to titanium if you want something to last.
