Grease / Lube
What are you cats using for a lube agent/grease?
IE: On metal dogbone drive shafts, pivot points, bearings, etc. WD-40 seems to attract too much dirt and makes more of a mess than it's worth. Thanks |
2Stroketim, you ask 10 people this question you will get 10 different answers. But for me personally I use Acer sin oil in my bearings, this stuff is awesome for that. As for drive shafts that use dog bones I would recommend some dry lube, like the kind used on bicycle chains.
I kinda figured that everyone would have their own ideas, just wanted to see what everyone was using.
I've been using the WD-40 Silicone formula, but I'm not liking it too much. Back in my motocross days, we used BelRay waterproof grease for bearings, and pivot points - I may give that a try |
Bearings - slip oil, no grease.
CVD's, AE black grease, or a good synthetic grease. |
Marvel Mystery Oil in an old motor lubing dropper. I don't lube cvd's at all in my 1/10 scale electrics. The pins to the outdrives wear out before the joints do IMO, oil/grease just makes the joints collect dirt.
Has anyone tried LPS 1 lube? We used to use it in a plant where I worked. I've never tried it on an RC vehicle, but it seems to actually repel dirt. I've thought of ordering some to try
LPS 1 lube would be good on dog bones and arms,etc but not bearings. Its a dry lube,probably Teflon. A thin oil, even synthetic is needed for bearings. Never use WD40 on bearings. Theres a long explanation why, not going into it here.
I use Avid bearing lube and AE black grease or Mugen grease
Originally Posted by sickpuppy1
(Post 14588135)
wd40 is the worst stuff for rc..... honestly, I really dislike wd40 in any application..... there are just so many better products out there
WD40 is a great tire sauce :)
Originally Posted by xjwolfpacker
(Post 14589865)
Originally Posted by Socket
(Post 14587498)
Dry lubes or semi dry (Boeshield T9) on cvd/Universal's. Any light oil in 1/10 bearings, light grease in 1/8 bearings.
Key to success with dry lubes: apply 10+ hours prior to use so all the carrier evaporates. |
