Vision Racing Products (VRP)
#121
I purchased some VX2 5x1.5 for my X-Ray XB8E and can't be happier.
At the time I purchased the pistons I also purchased an extra set of valves, I guess they are the hard valves. They have a Silver Dot on one end.
Do I have the "Hard Valve" or something else?
Thanks in advance for the info.
#122
#123
Thanks again and I like the pistons, Game Changers and VX2's.
Thanks for doing the work and massive amounts of research to produce a great product. We need more as yourself.
#124
Thanks, I will swap them this week and give them a try as I feel like I have a little to much rebound with the stock valves. Our track isn't the smoothest but it does have good traction even when its dry and dusty.
Thank you for the kind words. Here at VRP, we strive to make quality products. We are always looking to improve the quality standards in this industry. We are also proud to be able to say all of our products are made in house, 100% USA made.
#125
RC8B3 Throttle Linkage Brace
We here at VRP are always thinking of new products to come up with. Recently we started looking at the throttle linkage on nitro cars in general. Most nitro cars have some flex in the throttle servo area, espically under hard breaking. We started looking at my personal RC8B3. We noticed that there was a slight flex under hard breaking. This essentially causes more stress to your throttle servo, which over time can damage your servo. In testing, I was able to turn my brake EPA down over 20% and my brakes stay consistent throughout long mains. We have developed a new cnc top brace for the center diff that has a new hole drilled and tapped for the linkage brace ball stud. All of the components needed for the brace will be included in the kit.
#126
Slomo action video
Here's a couple of short slomo video of VRP pistons in action with a Tekno sct410.3 equipped with 5x1.5 pistons and 20wt Losi oil all around on super high traction clay.
https://youtu.be/iascQYzVuTM
https://youtu.be/TI52Igh2qc8
#127
Vision Racing Products B6/B6D Chassis Weights
VRP would like to introduce its first weights for the B6/B6D. These are aluminum 9 gram and 13 gram chassis weights. These will add more tune-ability to your B6/B6D. The weights will be sold separately and in a set. Available now on our website!
#128
Where do you mount your speedo and receiver with those?
#129
Tech Legend
+ YouTube Video | |
+ YouTube Video | |
#131
Smiley,
I think the confusion for mounting comes from the way the aluminum appears to be stepped ,as you milled the piece. Visually I would think unsmooth,or stepped. I have machining experience, and realize it is visually deceiving..I believe no problems at all with mounting electronics.
Any chance of steel being fabbed?
#132
Smiley,
#135
It's roughly .63lbs per cubic inch.
Cost more than Alumimum, Steel or Copper.
