Team Associated B6 & B6D thread
#7696
Ha. When I first did the search for PSM pistons your question from a few months ago came up but I never saw an answer ! Did you try them?
Those do look interesting... I assume they would act similar to a one sided taper piston, depending on which way the taper faces (typically down to allow quicker rebound) but adjustable !
#7699
Our track is outdoor clay / dirt mix, ie. we water and sweep, rips / DD's !
#7700
Take a look to https://drive.google.com/file/d/0B-9...BXMzI4SE0/view
Put 2x1.7 in the rear, white/green springs, 32.5wt all around and just send it !
#7701
#7703
Local hobby shop has exotek one 2 pc design motor plate. Anyone using it? Need some input 2 pc look weak though. Was looking for Jconcept 1 pc plate but sold out. Thanks.
#7704
I think the Exotek is better because it comes with the spur gear cover. Motor plates are all the same in thickness.
#7705
#7706
Simple question requires simple answers 😂
I've decided to run 13.5 stock instead of modified for a local winter series and Jesus is it slow! It's a spec motor for everyone so what stuff/mods would be required to make the car faster. What do you guys run running stock do?
Cheers
Cheers
#7709
Anybody try the 33g exotek c-block ?
https://www.amainhobbies.com/exotek-...xo1722/p581330
Is it a direct fit or does it need convincing?
#7710
Cheers
Cheers
653Likes
